Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
RE: braking performance
  Printable Version
Camaro Forum >> Camaro Models >> 3rd Generation >> V8 Tech >> RE: braking performance Page: <<   < prev  1 2 [3] 4   next >   >>
Login
Message << Older Topic   Newer Topic >>
RE: braking performance - 11/8/2006 10:32:38 PM
FlufyTiger
Status: offline
If I have time to, that'd be fine. I'm in school full time, and I work all the damn time. If there's a small leak, you might not even be able to see it. As for the parts rebuilding, it basically means that you'd be honing all the cylinders and replacing all the rubber and springs.
(in reply to microkid)
Post #: 21
RE: braking performance - 11/9/2006 6:31:11 PM
shnormo
Status: offline
shnormo's photo gallery
If you are drilling and taking away material from the rotor surface, how are you getting a greater surface area? Yes brake pads have a grove in them too to help dissapate heat. Since the rotors are allowing the gases to escape, it takes heat with the gases being evacuated therefore cooler brakes. They do let your brakes work more efficiently. I personally prefer slotted rotors instead of drilled for street/strip driving since the structual integerity is better and they don't crack as much. You'll get a longer service life outta them. You can also get Russell or Earl's Stainless steel braided brake lines that go to the calipers from the hard line and replaces the rubber one that bridges the hard line from the chassis to the rear diff.
quote:
ORIGINAL: FlufyTiger
I happened accross some fairly low priced ones on SummitRacing.com, not great, but not horrible at $70ish a piece. The cross drilled rotors will greatly improve your braking performance, as they disipate the thin layer of gas that builds between pad and rotor as the assembly heats (it's almost like a hydroplaning effect on your braking assembly) In additiong to that, the increase in surface area from the cross drilling will add to heat disipation, and all of this means reduced brake fade, and fade is your number one enemy in high speed braking. But like I said, if you still aren't satisfied with brake performance when you're done, look into suspension work, it's probably past due anyway. Nobody pays attention to shocks or struts anymore.
_____________________________
- Norm
http://www.cardomain.com/id/shnormo05
Rebuilding 79 Camaro
(in reply to FlufyTiger)
Post #: 22
RE: braking performance - 11/9/2006 6:34:13 PM
shnormo
Status: offline
It doesn't cost much more to buy new parts. Just look for the brake parts that are wet. Check it on the front soft brake lines and at all the connections.
quote:
right now, the tire pressure is prolly around 35-40 lbs. the front tires are bald on the outside, and nearly mint on the inside (hence my need for alignment and struts). the steel cords are showing on the front outsides. however, i didnt get any lock up, now the pulsation of abs interfering. i might go and do some testing of the brakes thursday when the parents arent home. the peddle is very firm, but it takes about half the peddle before the car starts slowing down.
Your car has struts and is designed with a little extra camber on the front that allows it to handle a little bit better hence the waring on the outside. Check your tires, the modern tires can usually hold up to 44 lbs of maximum pressure.
- Norm
Post #: 23
RE: braking performance - 11/9/2006 6:39:10 PM
shnormo
Status: offline
http://store.summitracing.com/partdetail.asp?autofilter=1&part=HWK%2DHB119Z%2D594&N=700+4294908216+4294908198+4294925022+4294922533+4294839009+115&autoview=sku
http://www.tirerack.com/brakes/results.jsp?autoMake=Chevrolet&autoYear=1986&autoModel=Camaro&autoModClar=&brand=&perfcat=perf&perfcat=track
- Norm
Post #: 24
RE: braking performance - 11/9/2006 10:22:40 PM
FlufyTiger
Status: offline
I think you're confusing surface area with pad contact area. The drilled holes provide more surface for air exposure than a solid rotor. The gas disipation helps more with keeping pad to rotor contact in line than heat disipation. As I said before, the gases build up between the rotor and the pad, and while the layer is extremely thin, and you can't even see that it's there, it's more than enough to cause excessive brake fade, which is also the primary reason for the slotted pads.
(in reply to shnormo)
Post #: 25
RE: braking performance - 11/9/2006 11:25:49 PM
microkid
Status: offline
i went and did some testing. from what my speedo was registering as 50 mph (i think it might be inaccurate), it took about 250 feet to stop using full brake. it locked them up around 10 mph and skidded about 10 feet. its still taking too much distance to stop, and since i live in a high deer population area, it concerns me. i checked the rear brake discs and a visual over the pads. theres minimal stepped wear on the disc (just a bit of a lip), and no grooves. the pads look a little worn though. i didnt get a chance to look at the front pads.
i looked at the hawk hps pads from the tire rack online store (sorry, i dont remember who gave me the link). that will on the front and rear brakes, right?
i guess i should look tomarrow and see if i have the dual piston calipers up front
< Message edited by microkid -- 11/9/2006 11:37:50 PM >
1986 Camaro Z28. Soon to have a mild 350 hp 350 with TPI. Trying to keep it looking factory. Can you say sleeper?
Post #: 26
RE: braking performance - 11/10/2006 11:15:26 AM
FlufyTiger
Status: offline
You should index those rotors too, see if they're getting even pad contact throughout the braking cycle. Were the rear pads worn evenly from front to back and and about the same amount for each pad?
Post #: 27
RE: braking performance - 11/11/2006 4:54:47 PM
microkid
Status: offline
i didnt take the pads out to see how they were worn, i just looked at what was visible. what i was told by a mechanic at a gm dealer (i was checking to see if there are any different braking systems for the camaro i.e. heavy or standard duty, and there isnt), and he told me its possible that the calipers can freeze from rust if allowed to sit long enough (and it sat over a year without being moved much). rebuilt calipers were $30, and my brother suggested to me that i replace the rear hoses while i was at it, if that is the problem. what are your guy's opinions?
Post #: 28
RE: braking performance - 11/13/2006 10:38:04 PM
FlufyTiger
Status: offline
That's your call. Personally, I'd rebuild the calipers myself. The supplies and tools needed are about the same price as a single caliper. If you wanna came down this way some time this or next week with the old calipers and the stuff needed, I can teach you how to rebuild the stuff. Might as well bring the wheel cylinders too. But make sure your bleeder screws open before removing anything from the car.
Post #: 29
RE: braking performance - 11/16/2006 11:01:38 AM
FlufyTiger
Status: offline
Eh, I know this is kinda old, but the only thing you'll get from over inflation is the center tread on the road, while outer isn't on the road. Once you get new tires, keep them at whatever the reccomended is. I THINK it's 32, but like I've said before, mine's been off the road for a while. If you can, find someone who has nitrogen and use that in the tires. It's like $2 a tire around here, and doesn't seep out or change volume or pressure in normal operating conditions like air does.
Post #: 30
Login OR Register now to post a reply to this forum topic.
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604220
madmikez284180
95slvrz283155
02stangt3002
74454bb2749
cplthomas2556
bluovlh8er2469
blade2300
spartan662261
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
