Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
Automatic shifting problem
  Printable Version
Camaro >> Camaro Models >> 4th Generation >> SS / Z28 Camaro >> Automatic shifting problem Page: [1]
Login
Message << Older Topic   Newer Topic >>
Automatic shifting problem - 8/11/2005 3:23:34 PM
richz28
Status: offline
At the top end of the 1/4 mile I need to shift into 3rd or drive, but my "z" won't allow me to do so. So, I have to take my foot off the pedal before she will shift. This is causing me to give my competition an opportunity to pass me. My car is, for the most part, stock. Even with this disadvantage, I'm running mid 13's, with street tires. Any suggestions?
Post #: 1
RE: Automatic shifting problem - 8/11/2005 6:25:48 PM
nj85z28
Status: offline
nj85z28's photo gallery
do you have a skip shift eliminator?
_____________________________
New Jersey F-Body Owners Association Member
CamaroForums.com Moderator
PontiacTalk.com Moderator
ClubGP Member #22259
(in reply to richz28)
Post #: 2
RE: Automatic shifting problem - 8/11/2005 6:46:35 PM
z28pete
Status: online
z28pete's photo gallery
What year & model is the car? What transmission are U using?
(in reply to nj85z28)
Post #: 3
RE: Automatic shifting problem - 8/12/2005 7:36:04 AM
richz28
Status: offline
No, I don't have a skip shift eliminator. My Z is a 2000 with the stock Automatic trans.. ps.. it's an LS1 car.. if that helps.
Post #: 4
RE: Automatic shifting problem - 8/12/2005 5:17:59 PM
nj85z28
Status: offline
well t hen you probably need the skip shift eliminator to get your gears back
Post #: 5
RE: Automatic shifting problem - 8/12/2005 6:28:56 PM
z28pete
Status: online
I would like to help but I need to know what exactly are you trying to do. I gather you have an automatic. Are you shifting the transmissiom manually and the shift lever won't go in drive, or the lever is in drive and the transmission won't shift up? Have u done any mods or reprogrammed the computer, changing rev limiter or shift points ? What happens if u take off in drive and leave it there for the entire run?
Post #: 6
RE: Automatic shifting problem - 8/14/2005 8:31:31 PM
richz28
Status: offline
Z28PETE.. good questions.. Yes, I'm manually shifting and when I put the shifter into drive, the trans won't up shift. I was told be someone at the track that I should quickly downshift to "1" and then into drive. I'm not really sure I want to do this.. for the obvious reasons. I havn't tried a run with the car in drive, so I don't know if that would work. And, yes I've hypertech'd the car. the Rev limiter is set to 6500 RPM's (not too high), and the shift firmness is at 100%. I'm thinking that I need to install a B&M shift kit, but I'm not sure if I have a 4l60e or a 4l80e trans..
(in reply to z28pete)
Post #: 7
RE: Automatic shifting problem - 8/14/2005 10:59:48 PM
z28pete
Status: online
Shifting down to 1 is not a good idea, the computer is supposed to pevent the transmission from shifting into first at the speed that you are traveling, bui it is not worth taking the chance. Try to set the shift points at least 300 RPM below the rev limiter setting. There is not much going on after 6000 rpm anyway and it will probably upshift better. Under certain conditions the computer will override whatever you are trying to do with thw shift lever. These cars are equipped with the 4L60E transmission which doesn't last too long when drag racing. The 4L80E would be a better choice, much stronger and has closer gear ratios, but it is bigger and more expensive.
The shift kit worked well for me till the tranny died; however I found it a little too harsh for street use.
Post #: 8
RE: Automatic shifting problem - 8/16/2005 8:38:23 AM
richz28
Status: offline
z28Pete... Thank you for you reply. I thought that the downshifting to 1 was a really stupid thing to do. Maybe the guy that told me this was a Mustang fan :) or someone I just beat... Bottom line is that I ordered the shift kit. Fortunately my wife doesn't drive this car, I do.. then I'm turning it over to my son to carry on.. so, if it's a little harsh, well ... that's ok. I really appreciate your help. Thanks Again..
Post #: 9
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro Forums >> Camaro Models >> 4th Generation >> SS / Z28 Camaro
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604220
madmikez284179
95slvrz283155
02stangt3002
74454bb2749
cplthomas2556
bluovlh8er2469
blade2300
spartan662261
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
