RE: Car failed inspection, and I need everyones help
Login | |
RE: Car failed inspection, and I need everyones help - 11/14/2006 11:23:55 PM
MadMikeZ28
Thanks Fluffy. But with my knowledge of computers and internet I lost you at the work link. And as for that pickle fork, I have never used on in my life. Just like said before, Smack the spindle where the stud for the balljoint goes through and it pops apart. And a friend to pry if there is no pressure from the spring to force it apart. But do watch that spring.
_____________________________
Its better to burn out than fade away "Is everyone on DOPE?" Golden teeth and golden tones, welcome to my presence
RE: Car failed inspection, and I need everyones help - 11/14/2006 11:47:37 PM
MadMikeZ28
This is third gen stuff here and it is a strut. the spring will decompress if you disconnect any one of the following, upper strut from bearing, strut from spindle, spindle from control arm.
RE: Car failed inspection, and I need everyones help - 11/14/2006 11:48:24 PM
FlufyTiger
Joined: 9/2/2006 From: Baltimore, Maryland Status: offline
Yeah, petroleum in brakes would be fun, though. Nobody would ever go anywhere without pushing serious torque. Only reason I asked about the brake fluid is that I hadn't heard of a glycol base brake fluid with a boiling point over 500 degrees, and silicone would be a bad option for anything that'll go for more than a month or two without changing the fluid.
RE: Car failed inspection, and I need everyones help - 11/15/2006 6:37:41 AM
1983camaro
quote:
ORIGINAL: FlufyTiger Well, first off, Chiltons. Haynes SUCKS. why is that, ive got a haynes books and ive gotten everything i needed done from that book.
www.my-camaro-project.piczo.com [image]http://img85.imageshack.us/my.php?image=cinci4ever1flashkv0.gif][IMG]http://img85.imageshack.us/img85/3822/cinci4ever1flashkv0.th.gif[image]
RE: Car failed inspection, and I need everyones help - 11/15/2006 9:57:57 AM
FlufyTiger
To name a few. In my Haynes for my 94 Toyota truck, it says the motor is carbed. They stopped using the carbed motor sometime well before that vehicle was made. They told one of the guys I go to school with that his Grand Cherokee 4.0L Inline 6 takes 4.5 quarts of oil. If you've ever worked in the industry in an all inclusive shop, you'd know that EVERY jeep straight six takes SIX quarts. All of them, no exceptions. Anyone who can print such blatant mistakes obviously isn't putting as much though into their work as they ought to. I can see getting oil capacity wrong, but to say that a 22RE is carbeurated, that's just stupid. Especially when there's a picture of a fuel injected motor in 8 different places on that 2 page span. You may have gotten everything done, but that doesn't mean that you'll never have problems with it. Oh, and the 1986 Buick LeSabre came with a 2.8L V6, not a 3.1, which I never would have known without Chiltons. Or that big ass logo emblazoned on the top of the engine in bright red and silver. Either one works.
RE: Car failed inspection, and I need everyones help - 11/15/2006 8:30:45 PM
MadMikeZ28
quote:
ORIGINAL: shnormo quote:
ORIGINAL: MadMikeZ28 This is third gen stuff here and it is a strut. the spring will decompress if you disconnect any one of the following, upper strut from bearing, strut from spindle, spindle from control arm. It's a Mcpherson strut right? Coil sits on a mount on the strut with an insulator at the bottom, and then it's got another insulator at the top then the strut bearing. Then the strut bearing is held onto the strut shaft with a nut therefore compressing the spring and allowing you to take it out and put it in w/o having to compress the spring? Thumbnail Image
No. The coils do not go on the strut. The coils sit on the lower a-arm and in a pocket in the cross member. The fourth gens have that kind of strut your are thinking of.
RE: Car failed inspection, and I need everyones help - 11/15/2006 8:37:08 PM
MadMikeZ28
quote:
ORIGINAL: 1983camaro quote:
ORIGINAL: FlufyTiger Well, first off, Chiltons. Haynes SUCKS. why is that, ive got a haynes books and ive gotten everything i needed done from that book. I totaly agree with Fluffy. I have seen too may things wrong in haynes and big lack of information. I have one for my 97 Astro van I needed for wiring and it has "typical wiring" which tell me absolutly nothing. The diagrams are typical in the 40's but not now. It was a waste.
RE: Car failed inspection, and I need everyones help - 11/15/2006 8:40:45 PM
microkid
Joined: 10/6/2006 From: Gettysburg, PA Status: offline
thanks for the help so far guys. i havent gotten the chance to look at all the links, or read it all. ill try and get some free time this weekend to look up parts from moog and carquest oh, and like i said, im only going for replacement parts, i cant afford to upgrade anything at this time.
< Message edited by microkid -- 11/15/2006 8:41:58 PM >
1986 Camaro Z28. Soon to have a mild 350 hp 350 with TPI. Trying to keep it looking factory. Can you say sleeper?
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
