Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
RE: Car failed inspection, and I need everyones help
  Printable Version
Camaro >> Camaro Models >> 3rd Generation >> RE: Car failed inspection, and I need everyones help Page: <<   < prev  1 2 [3] 4 5   next >   >>
Login
Message << Older Topic   Newer Topic >>
RE: Car failed inspection, and I need everyones help - 11/15/2006 9:42:30 PM
microkid
Status: offline
alright, the list from the mechanic is the following:
both lower ball joint
center link
both front brake hoses
both front rotors (stong suggest new bearings)
struts
i already have the struts. i figure i might as well get the hardware too because the 20 year bolts and what not are prolly extremely rusted. it doesnt say anything about replacing the pads, or doing the rear brakes. however, i am going to clarify everything tomarrow, and find out what he means by center link. i will probably replace the rear rotors, pads, and hoses while im at it.
_____________________________
1986 Camaro Z28. Soon to have a mild 350 hp 350 with TPI. Trying to keep it looking factory. Can you say sleeper?
(in reply to microkid)
Post #: 21
RE: Car failed inspection, and I need everyones help - 11/15/2006 10:13:21 PM
MadMikeZ28
Status: offline
When you have gotten used to driving with worn out **** New is like an upgrade.
Its better to burn out than fade away
"Is everyone on DOPE?"
Golden teeth and golden tones, welcome to my presence
Post #: 22
RE: Car failed inspection, and I need everyones help - 11/15/2006 10:17:44 PM
MadMikeZ28
Status: offline
The bolts on your struts are huge that go through the spindle. They dont wear out.
The center link is the part that the inner tie rod ends hook to. Look at the crossmember from the front underside of the car and it is a bar that goes across right in front of it. Not to be confused with the sway bar that crosses under the radiator support.
(in reply to MadMikeZ28)
Post #: 23
RE: Car failed inspection, and I need everyones help - 11/16/2006 6:21:31 AM
FlufyTiger
Status: offline
quote:
ORIGINAL: microkid
I believe that would be these, but you might wanna check, beacause you can never tell with some mechanics.
http://www.hawksthirdgenparts.com/index.asp?PageAction=VIEWPROD&ProdID=758
Post #: 24
RE: Car failed inspection, and I need everyones help - 11/16/2006 4:12:41 PM
MadMikeZ28
Status: offline
Those are sway bar end links Fluffy
this is a center or sometimes called drag link
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MOG%2DDS1049&N=700+4294908216+4294908198+4294924928+4294925130+4294839070+4294839413+115&autoview=sku
(in reply to FlufyTiger)
Post #: 25
RE: Car failed inspection, and I need everyones help - 11/16/2006 8:19:46 PM
shnormo
Status: offline
shnormo's photo gallery
The center link is the thing that is connected to the inner tie rods, the idler arm, and the pitman arm. Therefore Mad Mike, you are correct. You might as well replace the bearings in the rotors. They ware the races inside the rotor and the bearing needles also wear down. If you install old bearings with new races, there is extra play and they are not worn together properly. Rule of thumb, NEVER mix new bearings with old races or vice a versa. If you do replace them make sure you pick up a seal for them too. Also get some good high quality bearing grease. Take the bearings outta the packaging and then put a glob of grease on your plam and work the grease into the bearing with the rollers going parallel with the motion. You don't want to roll the grease in there because it supposedly causes premature ware. Apply liberally. Get more cotter pins also and don't over tighten the castle nut on the spindle holding the whole thing on, and don't make it too loose either. Get it hand tight and then about a 1/4 turn past and line up the hole on the spindle with the castle nut so you can put the cotter pin back in.
- Norm
http://www.cardomain.com/id/shnormo05
Rebuilding 79 Camaro
Post #: 26
RE: Car failed inspection, and I need everyones help - 11/16/2006 8:35:32 PM
uncle bill
Status: offline
Mmmm....Suspension repair 101. All of You guys are making great points, but I think the kid needs more $$$$ to do everything He needs to. Microkid, do some serious price comparisions. There is a huge variance of pricing in suspension parts. I've seen the exact same part sell for $15 at Autozone and $75 at carquest. Same brand, same part number. Be Careful how You spent the little money You have to work with.
(in reply to shnormo)
Post #: 27
RE: Car failed inspection, and I need everyones help - 11/16/2006 8:58:39 PM
MadMikeZ28
Status: offline
quote:
ORIGINAL: shnormo
Thanks, but I had no question in my mind that I was correct. And I am DAMN sure I am correct about the struts and springs not being one unit.
Post #: 28
RE: Car failed inspection, and I need everyones help - 11/16/2006 10:20:05 PM
shnormo
Status: offline
Ok... I was just confused cuz it's 1 unit on the 86 Trans Am. Take the bolts out of the strut mount. And then the two bolts at the spindle and then it came out as an assembly. Used a McPherson Strut compressor then took out the nut on the strut shaft and then took the mounting bearing off and then the spring and assembled in the reverse order.
- Norm
Post #: 29
RE: Car failed inspection, and I need everyones help - 11/16/2006 11:27:37 PM
FlufyTiger
Status: offline
Gotcha. I'm pretty new to the suspension thing, since I mostly do electrical and brake jobs. I'm learning suspension, but it's tough to do that when I've got no cars needing suspension work.
Post #: 30
Login OR Register now to post a reply to this forum topic.
Camaro Forums >> Camaro Models >> 3rd Generation
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604220
madmikez284179
95slvrz283155
02stangt3002
74454bb2749
cplthomas2556
bluovlh8er2469
blade2300
spartan662261
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
