RE: Car failed inspection, and I need everyones help
Login | |
RE: Car failed inspection, and I need everyones help - 11/17/2006 1:33:05 AM
MadMikeZ28
quote:
ORIGINAL: shnormo Ok... I was just confused cuz it's 1 unit on the 86 Trans Am. Take the bolts out of the strut mount. And then the two bolts at the spindle and then it came out as an assembly. Used a McPherson Strut compressor then took out the nut on the strut shaft and then took the mounting bearing off and then the spring and assembled in the reverse order. You are still confused. The 82-92 Firebirds are the same chassis as the 82-92 Camaro's. Same strut and coil configuration. Maybe you are thinking of a 96 T/A
_____________________________
Its better to burn out than fade away "Is everyone on DOPE?" Golden teeth and golden tones, welcome to my presence
RE: Car failed inspection, and I need everyones help - 11/17/2006 10:53:21 AM
uncle bill
Joined: 9/3/2006 From: San Antonio, Texas Status: offline
C'mon Mike..................Remember Your heart, don't get too worked up......Luv ya man.
RE: Car failed inspection, and I need everyones help - 11/17/2006 4:29:16 PM
microkid
Joined: 10/6/2006 From: Gettysburg, PA Status: offline
Alrighty, I stopped at Napa and heres what I got: centerlink (entire unit) $50 front inner bearing $8.31 each front outer bearing $10.05 each seals $2.20 each Rotors are $36.73 each front; $45.62 rear (I have found these cheaper online from brembo) brake pads are $20.99 pair front ($42.70 premium), and $20.99 rear pair ($41.16 premium) X2 each (the hawk pads are cheaper i do believe) brake hoses are LF $15.11 RF $14.25 Rear $21.25 (im assuming the pair?) Ball joints are $13.56 each with the hardware. I had no luck finding the bolts and the top nut and whatever else is used to attach the struts to the car. I'm going to check autozone tonight.
1986 Camaro Z28. Soon to have a mild 350 hp 350 with TPI. Trying to keep it looking factory. Can you say sleeper?
RE: Car failed inspection, and I need everyones help - 11/17/2006 7:33:21 PM
MadMikeZ28
quote:
ORIGINAL: uncle bill C'mon Mike..................Remember Your heart, don't get too worked up......Luv ya man. Oh Yeah. Thanks for the reminder Uncle Bill. If I keep this up I am going to have to get the battery in my defibrilator replaced sooner. MICROKID The new struts should come with new locknuts and the bolts that attach it to the spindle are strong and should be fine.
RE: Car failed inspection, and I need everyones help - 11/17/2006 8:40:48 PM
microkid
i think they may have come with them, but im not positive. i did find a hardware kit though, just in case i break something. i also picked up the ball joints today, only cost me $19. but thats because i took back belts that i had a 10% discount on (but i lost the receipt, so i got full price back), then used that towards new ball joints minus a 10% discount.
