RE: Car failed inspection, and I need everyones help
Login | |
RE: Car failed inspection, and I need everyones help - 11/28/2006 9:27:15 PM
microkid
Joined: 10/6/2006 From: Gettysburg, PA Status: offline
im trusting my dad to install my brake pads, rotors, and bearings. luckily, it goes right into inspection after im done.
_____________________________
1986 Camaro Z28. Soon to have a mild 350 hp 350 with TPI. Trying to keep it looking factory. Can you say sleeper?
RE: Car failed inspection, and I need everyones help - 11/28/2006 10:46:35 PM
MadMikeZ28
After some of the **** I have seen I almost wish there were inspections here. Like the nerve of people to drive down the road, smash into some one and then admit they knew thier brakes did not work. I think that is worse than drunk driving because you are not under any influenc and should be able to make better decsisions
Its better to burn out than fade away "Is everyone on DOPE?" Golden teeth and golden tones, welcome to my presence
RE: Car failed inspection, and I need everyones help - 11/28/2006 10:51:19 PM
FlufyTiger
Joined: 9/2/2006 From: Baltimore, Maryland Status: offline
Agreed. I've been pushing for yearly inspections that are slightly more lax than the one time we have now. I could care less about the **** that's coming out of the tailpipe, I can go around that, but no brakes kill people NOW.
RE: Car failed inspection, and I need everyones help - 11/29/2006 9:35:47 PM
microkid
well, the hawk hps brake pads dont fit. they are designed not to be used with an oem style, vented rotor. they are about half an inch too thick to fit over the rotor. and the company i bought them from are only going to give me store credit. what am i going to do with $100 store credit from a company i dont trust or dont need parts from?
RE: Car failed inspection, and I need everyones help - 11/29/2006 10:47:41 PM
FlufyTiger
Well WTF did they make a performance pad for a 2 ton car designed for non-vented rotors for? That's retarded. I would call them on the stupidity of the product and tell them you'll never buy from them again unless they give you a cash or credit refund.
RE: Car failed inspection, and I need everyones help - 11/30/2006 1:13:34 AM
MadMikeZ28
Notify the Better Business Bureau and let them contact Hawks. The BBB will inform them of your complaint and what you want done then notify you with the options given. Some people rather deal with it than have a mark against them for others to see. You can even check and see if they had prior complaints. Then smack yourself for buying $100 dollar brake pads.
RE: Car failed inspection, and I need everyones help - 11/30/2006 10:52:22 AM
FlufyTiger
Oh yeah, I completely forgot that part. The only way you should be spending that much on pads is for sintered metalics, and since you aren't A: Flying a plane B: Racing Circle Track or C:Racing Indy cars, you don't need, or want, for that matter, sintered metalics. $70 should be the most you ever spend unless you've got a custom brake system with 4, 6 or 8 piston calipers.
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
