RE: Hupereutectic Pistons
Login | |
RE: Hupereutectic Pistons - 11/23/2006 11:02:20 AM
FlufyTiger
Joined: 9/2/2006 From: Baltimore, Maryland Status: offline
They are higher, and some of the better brands use as much as five times the amount of detergent in their premium gas as what's required by law. The higher octane is ussualy obtained from Ethanol, ussually derived from corn in this country, although other grains can work, and Brazil, which uses E85 for something like 60% of it's vehicles gets it from sugar cane, in something that resembles uber-rum. 93 Octane can use as much as 10% Ethanol and still be called gasoline. The real issue here is that gasoline ignites at a lower temp than ethanol, and burns more rapidly, which leads it to be more prone to detonation. The Ethanol promotes a slower burn, and more even fuel consumption. I've never heard of 93 Octane hindering performance, how exactly does that work?
RE: Hupereutectic Pistons - 11/23/2006 1:34:33 PM
FlufyTiger
quote:
It is my opinion that in a low compression 8:1 engine that because of the caloric value of the fuel additive and no need to stop detonation the fuel will produce less power.... but this is only my opinion I could be wrong.. I'm thinking that MAY be incorrect. I mean, seriously, have you ever watched a thin older woman next to a large body builder at a driving range? The guy is strong, but never played golf before, so he hits hard and fast, and is quite satisfied with his 200 yards. Then, theres an old lady of about 55 or so, who's been golfing for years. She calmly draws back, hits smoothly and confidently right in the ball's sweet spot. 310 yards. The big guy is 87 Octane, hits hard and fast, but not as smoothly as he could, and he may have more power in him, but he can't focus it the way it needs to. The woman is 93, she's not as strong, and she may have less mileage in her, but she damn sure knows where to put the power she DOES have. Just a thought.
< Message edited by FlufyTiger -- 11/23/2006 3:20:07 PM >
RE: Hupereutectic Pistons - 11/23/2006 2:45:53 PM
Slayer
TIGER- im loving that saying, funny stuff
RE: Hupereutectic Pistons - 11/25/2006 9:21:50 AM
uncle bill
Joined: 9/3/2006 From: San Antonio, Texas Status: offline
I think that there are a whole lot of confused people here about " octane ". I've explained this before but I'm going to do it for the benefit of all those in doubt. I have extensive knowledge because of a personal relationship with Steve Burns who is the founder and CEO of VP Racing Fuels. Steve began VP in the back of Our Race shop in San Antonio, Texas in the mid 1970's. He was my wifes back neighbor as they grew up. As He has pounded into My head many times, Octane is a word used to give the average person an idea ohow automotive fuel works. Octane used by the big companies and is posted on gas pumps is derived at via a formula that is very complicated and does not relate to race fuel at all. First of all, octane is not raised or lowered by the use of any form of alcohol. The amount of hydrocarbons ( percentage ) is what controls burn rate ( octane ). A high burn rate ( less octane ) has a lower percentage of hydrocarbons. An engine that has high compression ( above 10-1 ) needs a slower burning fuel ( higher Hydrocarbons to make the burn last longer ) to allow the engine to use the fuel at a different rate so it does not use up the fuel before the burn cycle ( firing stroke ) before the cycle is complete. When You hear an engine pinging or detonating, it's because the fuel has been burnt too quickly and it needs a slower burning fuel, or less ignition timing. The reason the timing is important, is because the more advanced the timing is, the sooner the burn starts. By retarding the timing, You reduce the burn time requiring less octane. A Race engine with upwards of 17-1 compression requires a very slow burning fuel making the need for a speciality fuel such as VP's C16 which has 20% hydrocarbon content a requirement. Engines with 12-1 can run fine on C12 which has a 12 % hydrocarbon content. Expanding on this, An engine using NOS does very well when using C16 as the fuel injected with the NOS from a seperate fuel cell. It helps slow the burn rate and helps prevent burning up all of the fuel with the NOS. So, what the major fuel companies do, is to add hydrocarbons to increase " octane " and slow the burn rate. The use of any form of alcohol or ethanol is for different purposes. An engine will only have unused fuel if it's running rich ( just too much fuel volume for the engine to burn ). Modern fuel injected cars will computer compensate for this by sending less fuel through the injectors, It will also use the knock sensor to retard the timing to eliminate detonation. I know this is a bit long winded but I feel that everyone that has a performance car should understand this process so they can know the reason for the fuel requirements of their car.
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
