RE: Hupereutectic Pistons
Login | |
RE: Hupereutectic Pistons - 11/28/2006 10:42:49 PM
69camaro1
Has anybody acuatally had first hand experance with this compression and 87 or 89 octane?
RE: Hupereutectic Pistons - 12/3/2006 10:16:13 PM
69camaro1
If I run Dart pro 1 heads could I use pistons that create 9.25.1 compression and end up with 10.25.1 compression. I read that aluminum heads add 1 point of compression. If this is true could I use Hupereutectic Pistons to acheive this compression?
RE: Hupereutectic Pistons - 12/4/2006 12:11:06 AM
FlufyTiger
Joined: 9/2/2006 From: Baltimore, Maryland Status: offline
Who told you that aluminium anything adds compression? The material the parts are made of has nothing to do with the actual compression. Aluminium will allow you to achieve higher compression on pump gas, but that's about it. What you need to worry about for compression is piston volume, like Griff said, combustion chamber volume, head gasket thickness, and piston to deck clearance, as all of these things affect the amount of BDC cylinder volume to TDC cylinder volume, which is where the compression numbers come from. The fact that it's aluminium won't change this in the least.
RE: Hupereutectic Pistons - 12/4/2006 6:05:50 PM
uncle bill
Joined: 9/3/2006 From: San Antonio, Texas Status: offline
It does get a bit complicated, don't it?
