stall converter
Login | |
stall converter - 4/25/2004 1:11:18 PM
melissa
Joined: 4/23/2004 From: United States Status: offline
yes i have a 69 camaro, question my father says i need to install a stall converter, don't know to much about cars asked what is it and he doesn't even know. can anybody tell me what a stall converter is, and what it does. i would appreciate that.
RE: stall converter - 10/30/2004 11:57:10 PM
straightline81
hey, im a new member too but i can help you're request. first all automatic cars have stall converters also known as torque converters. the reason being is that automatic cars obviously don't have a clutch pedal. so if you are in you're car and stopped in traffic you're engine has to be able to spin without being coneccted to the drive shaft other wise it would stall. as far as where it is. its a piece inside those magical workings of you're automatic trans. for pictures visit any parts website and look for torgue converters of stall converters. what one must do to put a new one in is unknown to me but im almost positive the tranmition must be disconnected. i hope i've been able to anwser you're question. for any others i might be able to help with feel free to write -the mad hatta
RE: stall converter - 11/8/2004 7:37:53 PM
Rockaholic5002
A converter is a clutch in the auto trans world. Your stock converter will stall or make a direct drive with the mototr and the the tranny when the motor reaches around 1000 to 1800 RPMs , Stall converters range from 1800 for small camshaft applications all the way to 6000 stall for a transbrake and full out race cars with huge cams. You don't need a stall converter unless your car tries to edge forward when you have applied full break pressure or it won't idle right. IF you do need to swap out, reasearch and find out what size cam you have, let me know, and I can give you a rough guess on what size. Installing it isn't hard. Jack the car up, take out the drive shaft, undo the shifter linkage, undo the speedo cable and kickdown cable to the carb, there are six bolts holding the tranny to the motor take those out after you have supported the engine with another jack and taking the tranny loose from the crossmemeber, rent a tranny jack, lower the tranny out of the car with the jack, take out the old torque converter ( this would also be a good time to replace the front seal in the tranny), put the new one in, you should hear a clunk when you install the new one, you will have to spin it on the pump shaft to do so, the clunk lets you know it has mated with the pump, reverse the removal procedure, top off the tranny with fluid and your ready to go.
_____________________________
1980 camaro coupe 400hp 350
RE: stall converter - 1/8/2005 9:54:12 AM
tee
You sound like you know what you're talking about. I hope you can help me. I have two questions: 1. Do you know anything about the head casting number 14102193? From everything I've read, this head comes with either a flat tappet with edge bolt valve covers or with a roller cam with center bolt valve covers. My dilemma is that I have flat tappets with center bolt valve covers! I cannot find any info about this combination. If you know anything about this, please let me know. 2. Do you know what rear end (differential) came originally on the 6 cylinder automatic 67 Camaro? Thanks so much for your trouble, Tee
Want to make money on the net? http://smartauthor.com/treasures.html
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
