Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
2.8 V6-3.4 V6
  Printable Version
Camaro Forum >> Camaro Models >> 4th Generation >> V6 Tech >> 2.8 V6-3.4 V6 Page: [1]
Login
Message << Older Topic   Newer Topic >>
2.8 V6-3.4 V6 - 8/30/2005 4:50:48 PM
nj85z28
Status: offline
nj85z28's photo gallery
The main thing to remember about this swap is you are trying to re-create your 2.8 but on a 3.4 block. Why? to fool inspection personnel, the engine will look like your old one but definitly out-perform it! Also, to avoid computer wiring nightmares, and to simply get more out of your V6 for probably 1/3 of the price of the V8 swap. You have to re-use as much as possible, and this swap should finish around the $800 mark, engine block included
Order the block-
3.4 Litre block w/ intake, exhaust manifolds, oil pan
Buy a new Timing Chain and water pump
change everything over from the 2.8 to the 3.4, front to back, side to side,
Harmonic balancer and all
Swap 3.4 injectors to 2.8 fuel rail
Re-Use old distributor
Things to buy-
Complete 2.8 gasket set
Rear main seal
Distributor gasket
Exhaust manifold donuts
Of course, this list is not complete but it is close i would say. Simply buy the 3.4, and study it, then when you are completely comfortable handling it, pull that 2.8 out and change all the parts that are different on the 3.4. You want your 3.4 to look almost exactly the same as the old 2.8! When its all said and done, you should have spare 3.4 parts to make some of your money back!
_____________________________
New Jersey F-Body Owners Association Member
CamaroForums.com Moderator
PontiacTalk.com Moderator
ClubGP Member #22259
Post #: 1
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5507
spectergt2603834
madmikez283764
95slvrz282914
74454bb2688
02stangt2554
cplthomas2487
bluovlh8er2418
blade2300
ninetysixyen2078
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
