Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
FREE Iridium Plug contest!!!
  Printable Version
Camaro >> Camaro Classifieds >> Vendor Special Buys >> FREE Iridium Plug contest!!! Page: [1] 2   next >   >>
Login
Message << Older Topic   Newer Topic >>
FREE Iridium Plug contest!!! - 12/7/2006 2:29:21 PM
Sparkplugs.com
Status: offline
SparkPlugs.com is holding a spark plug contest! You will find a spark plug quiz below, all of the answers can be found on our website. Please e-mail your answers to Natasha@SparkPlugs.com. The contest is open until December 22nd. Any member with 25 posts or more can participate. Whoever gives the most accurate answers, or gets the most correct, will receive one set of NGK iridium spark plugs on the house. The winner will then need to do an installation and product performance review within 2 weeks after they receive the plugs. The review should show their installation process and a review of their impression of the product and its performance. Let me know if you have any questions!
Spark Plug Quiz:
1. What are the 9 product brands carried by SparkPlugs.com?
2. How many of those are spark plug manufacturers?
3. What are the three precious metals premium spark plugs are made out of?
4. Are standard spark plugs made with copper or nickel?
5. What does RFI stand for, and how do you prevent it?
6. Can Platinum plugs be used with nitrous?
7. Can Iridium plugs be used with nitrous?
8. What are 5 types of modifications that may make it necessary to change your spark plug heat range?
9. What is the heat range vs. hp increase rule of thumb?
10. Is it better to have too hot or too cold a plug? Why?
11. Do “fine wire plugs” refer to the ground electrode or center electrode?
12. What are two benefits of fine wire plugs?
13. What are the two precious metals used on fine wire plugs?
14. How is iridium superior to platinum?
15. Why is iridium used on fine wire plugs?
16. Which plug manufacturer makes the thinnest fine wire iridium center electrode?
17. Should Iridium plugs be gapped?
18. How long do iridium plugs last?
19. Why should I always check the gap before I install new plugs?
20. How can I find the proper gap for my motor?
21. What is the maximum I can open or close the gap?
22. How do I properly gap a plug?
< Message edited by Sparkplugs.com -- 12/7/2006 3:19:03 PM >
Post #: 1
RE: FREE Iridium Plug contest!!! - 12/8/2006 2:06:49 PM
94CamaroSFI
Status: offline
94CamaroSFI's photo gallery
I qualify expect an email
_____________________________
94 Camaro 3.4L Manual Transmission, CAI, Magnaflow Exhaust
91 3.1L RS manual, CAI, 3.42 Rear end gears, Catback
(in reply to Sparkplugs.com)
Post #: 2
RE: FREE Iridium Plug contest!!! - 12/22/2006 11:06:11 AM
camarorz28
Status: offline
so who won???
(in reply to 94CamaroSFI)
Post #: 3
RE: FREE Iridium Plug contest!!! - 12/25/2006 1:03:42 AM
Sparkplugs.com
Status: offline
And our winner is AW1551!
Congratulations and thanks everyone for participating!
(in reply to camarorz28)
Post #: 4
RE: FREE Iridium Plug contest!!! - 12/25/2006 2:17:40 AM
Sparkplugs.com
Status: offline
I thought i'd post the answers to the quiz for any who are interested.  The short, simple answer is first, with a more detailed explanation below it.  You guys found some loop-holes and trick questions that i didn't even know i created, so i hope this answers any questions!
Spark Plug Quiz:
K&N, Autolite, Denso, KYB, NGK, Champion, Splitfire, AFE, and Michell1 Manuals
AFX Air/Fuel Ratio Monitors are a product made by NGK
Autolite, Denso, NGK, Champion, Splitfire
Gold Palladium, Platinum, Iridium
Nickel
All spark plugs (iridium, platinum, standard, etc.) have a copper core running through the center.  When we're talking about plug types or metal types (platinum, iridium, nickel) we're referring to the material the electrodes are made of.  Copper is too soft to use on any exposed part of the plug,
so the electrodes on standard spark plugs are made with nickel.  No one understands why standard plugs are referred to as "copper plugs" - this designation is inaccurate.
radio frequency interference - and you can prevent it by placing a resistor within the spark plug.
No. There have been instances where the platinum tip has lost its bond to either the center or the ground electrode when used with nitrous.
Yes, according to the techs, there have been no reported problems with using iridium plugs with nitrous (or a blown alcohol motor.)
If you make modifications such as a turbo, supercharger, increase compression, timing changes, use of alternate racing fuels, or sustained use of nitrous oxide, these can alter the plug tip temperature and may necessitate a colder plug.
A rule of thumb is, one heat range colder per modification or one heat range colder for every 75–100hp you increase.
The most accurate rule to go by would be one heat range colder for every 75-100hp you increase, as some mods do not increase horsepower, and therefore do not neccesitate a change in heat range.
When making spark plug heat range changes, it is better to err on the side of too cold a plug. The worst thing that can happen from too cold a plug is a fouled spark plug, too hot a spark plug can cause severe engine damage
Center Electrode
There are many variations to the center electrodes and ground electrodes that come under a variety of names.  Specialized center electrodes may be called Fine wire, tapered point, ultra-fine electrode, taper cut electrode, necked down electrode, v-power electrode.  Specialized ground electrodes may be called V-trimmed, trapezoid cut, cut back ground, fine wire ground, wedge shaped ground, inverted v-tip, tapered cut, trimmed side electrode, angled ground strap, u-groove.  The ground electrode features add slight benefits to the plug, however, the family of fine wire center electrodes bring great improvements and the term "fine wire plugs" refers to plugs with a fine wire center elec
Post #: 5
RE: FREE Iridium Plug contest!!! - 1/10/2007 9:32:23 PM
aw1551
Status: offline
So how do I claim my winnings?
Post #: 6
RE: FREE Iridium Plug contest!!! - 1/11/2007 9:23:02 PM
z28pete
Status: offline
z28pete's photo gallery
Very carefully.
Pete
(in reply to aw1551)
Post #: 7
RE: FREE Iridium Plug contest!!! - 1/11/2007 9:28:52 PM
Andross
Status: offline
CONGRATS MAN!! You gonna share with me?
Current Project:
1979 Camaro
(in reply to z28pete)
Post #: 8
RE: FREE Iridium Plug contest!!! - 1/12/2007 2:48:59 PM
Sparkplugs.com
Status: offline
quote:
ORIGINAL: aw1551
e-mail was sent at end of contest - e-mail me at natasha@sparkplugs.com if you didn't receive it.
Post #: 9
RE: FREE Iridium Plug contest!!! - 2/14/2007 2:48:28 PM
aw1551
Status: offline
You guys have amazing services and I love you guys.  I'm going to recomend you to every one I know.
Post #: 10
Login OR Register now to post a reply to this forum topic.
Camaro Forum >> Camaro Classifieds >> Vendor Special Buys
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5504
spectergt2603831
madmikez283748
95slvrz282906
74454bb2688
02stangt2516
cplthomas2474
bluovlh8er2417
blade2300
ninetysixyen2078
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
