3.8 V6 INFO/MODIFICATION GUIDE
Login | |
3.8 V6 INFO/MODIFICATION GUIDE - 2/28/2007 10:02:25 AM
badinfluenceRS
3.8L V6 INFO L36 3800 Series II (3.8L/231ci) OHV 90* V6 (Bore 3.8in/Stroke 3.4in) Compression Ratio: 9.4:1 Firing Order: 1-6-5-4-3-2 Injector Size: 22lbs Intake Manifold: 95-98 Angled, 99+ Straight Throttle Body: 65mm Hitachi Thermostat: 95-98 195*, 99+ 180* Flywheel HP: 200 @ 5200 rpm Flywheel TQ: 225 @ 4000 rpm Gears: 3.08 Auto, 3.23 Standard, 3.42 Y87 3800 PERFORMANCE PACKAGE (Y87) Limited Slip Differential (G80 Code: 96-98 Auburn, 99-01 Zexel-Torsen) P235/55R16 Goodyear Eagle Tires Dual Outlet Exhaust Sport Steering (14.4:1 ratio, same as V8 Cars) Four-wheel Disc Brakes (J65 Code) RS PACKAGE Although many cars say 'Camaro RS' on the title, this does not mean they have a true RS Package. The RS Package Consists of: 3-Piece Rear Spoiler (extension on the stock spoiler) Full ground effects (front, side skirts and rear) Alloy Rims RS Exterior Badges BOLT-ON MODIFICATIONS Exhaust: Headers High flow headers replace the restrictive stock manifolds, adding power and improving sound. Pacesetter Headers Part #: PSM-70-1209 (painted) PSM-72C1209 (ceramic) Available: www.summittracing.com $234.39 Painted, $376.39 Ceramic www.texas-speed.com $204.99 Painted, $319.99 Cat-Back Cat-Back systems are basically the entire exhaust system after the catalytic converter. Mandrel bent pipes flow better than stock pipes, and a high flow muffler replaces the restrictive stock muffler. Thus improving performance and sound. Flowmaster American Thunder Cat-Back Part #: FLO-17358 (98-02) FLO-17357 (95-97) Available: www.summittracing.com $285.88-$304.99 + SH Hooker Aero Chamber Cat-Back Part #: 7-16811 (98-02) Available: www.texas-speed.com $349.99 Edelbrock RPM Cat-Back Part #: EDL-5658 Available: www.summittracing.com $283.95 Pacesetter TFX Kat-Back Part #: PSM-86- Available: www.summittracing.com $259.99 Magnaflow Performance Cat-Back Part #: MPE-15693 Available: www.summittracing.com $427.95 Borla Cat-Back Part #: BOR-14813 Available: www.summittracing.com $885.99 Mufflers High flow mufflers replace the stock restrictive muffler, thus increasing flow and improving performance and sound. Hooker Aero Chamber Muffler Part #: 7-21721 Available: www.texas-speed.com $89.99 Flowmaster 80 Series Muffler Part #: 42583 Available: www.racerpartswholesale.com $101.61 Magnaflow Performance Muffler Part #: MPE-14277 Available: [link=http://www.summittracing.com]www.summittr
< Message edited by z28pete -- 8/30/2007 8:52:57 PM >
_____________________________
1999 Camaro Z28 - LS1 / A4
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
