Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
RE: cam ready
  Printable Version
Camaro Forum >> Brand Review >> Engine & Internal >> RE: cam ready Page: <<   < prev  1 [2] 3   next >   >>
Login
Message << Older Topic   Newer Topic >>
RE: cam ready - 3/21/2007 12:12:54 AM
359pete
Status: offline
thanks griff, i spoke with the tech at summit, he says i will only get like 300lbs of torque because of the dished pistons. that just doesnt sound right to me. and of course the cam is to big for vortecs. i was expecting ( hoping for)alot more torque than that. there is a smaller cam revs to 5500 rather than 5700 capatable / vortec ill look a little deeper in that direction also check out cranes cam card          thanks again        359 pete
(in reply to GRIFF)
Post #: 11
RE: cam ready - 3/21/2007 9:14:27 AM
GRIFF
Status: offline
GRIFF's photo gallery
I was thinking about this a little and I think we can figure out more if we knew the piston spec. Is there a name or part # on the piston. Can you get a picture of the piston and post it maybe someone can match it up. Question for the machine shop guys.. is there a way to measure the piston volume like you would head volume?? Once we have this we can figure out the compression ratios, static and play with the dynamic on cam choice. 300 ft/lb is bs for your 400 by the way.
(in reply to 359pete)
Post #: 12
RE: cam ready - 3/21/2007 1:07:02 PM
359pete
Status: offline
checked out cranes cam reccomendation. they suggest using part# 113522 cam kit 218/230 @ .050 .459/.486this is their Z cam . the .486 is what im worried about. smaller cam may just have to be the answer.                      THANKS                       359PETE
(in reply to GRIFF)
Post #: 13
RE: cam ready - 3/21/2007 9:32:44 PM
GRIFF
Status: offline
The cam recommendation they gave is a split duration cam they try to compensate for the less flow of the exhaust by increasing lift and duration of the exhaust. The exhaust flow is weak when compaired to the intake in the vortecs. This is what we are doing with our budget 350 we have a 270 magnum cam its a single duration .470 lift cam  we got a set of the vortecs stock used. To use the cam we figured we would just port the exhaust side mild port cleanup contour the valve guide and slightly increase the throat area just cleanup the intake these heads already have 3 angle valve job stock(except certion 906 castings with the hardened valve seats) I am getting a little stronger springs and through the measurements I already mentioned I need .010 additional clearance being the backwoods mechanic I am I sanded .010 off the backs of the retainers to get the clearance. There are several other ways to handle the clearance issue 1) take it to the machine shop have the guides cut down with new seals $100 2) beehive springs and special retainer $200 3) there is a guy selling umbrella seals on ebay for $40 with springs(not to sure on this one) 4) sand down retainers (very minimal gain) but should work for us $ emery cloth. 5) buy the cetter and do them your self $80  If you find it necessary to go to bigger springs the spring pockets need to be enlarged comp makes a cutter or a machine shop could do it.   I could go on and on but just to tell you I assumed a 12cc dish on your pistons and ran the 270 comp cam on desk top dyno and found your torque to be in the upper 400ft/lb range at 3500 rpm just got to love the 400....
Post #: 14
RE: cam ready - 3/22/2007 11:21:30 AM
359pete
Status: offline
found out it is possible to grind a litte fat off the bottom of the retainers to gain the clearance i desire. what do yall think of this idea.        359PETE
(in reply to GRIFF)
Post #: 15
RE: cam ready - 3/22/2007 4:59:02 PM
359pete
Status: offline
what is a pc seal cutter and where do i need to go to get one?                   359 PETE
(in reply to rat454)
Post #: 16
RE: cam ready - 3/22/2007 8:18:54 PM
GRIFF
Status: offline
Summit Jegs also called valve guide cutter, you might also consider valve spring cutter for bigger springs. Here is a tread where they discuss options I think they have a section for vortec heads http://www.nastyz28.com/forum/showthread.php?p=534999
Post #: 17
RE: cam ready - 3/23/2007 7:53:59 PM
machineman
Status: offline
I recommend lowering the valve guides to allow for the extra lift. The retainer hitting the seal and or guide will cause a lot of headaches!
_____________________________
Chris Crossont
A.H.M. Performance
Baltimore, MD
http://www.ahmperformance.com
(in reply to GRIFF)
Post #: 18
RE: cam ready - 3/23/2007 7:55:51 PM
machineman
Status: offline
quote:
ORIGINAL: GRIFF
Machineman,  Nice website and a heck of a nice looking shop. One question regarding the .500 lift on the vortec heads, I have a set we are playing with now I measure .518 inches of travel before the retainer hits the top of the valve seal Ive read where you need .060 inches of clearance to be safe which puts you at .460 of valve lift. How does the Z28 spring help with this situation with the retainer being the issue do you need to change the retainer also.
Thanks for the compliment! I really do appreciate that. It looks like a missed a lot over the past week.
Chris Crossont
A.H.M. Performance
Baltimore, MD
(in reply to GRIFF)
Post #: 19
RE: cam ready - 3/23/2007 7:56:50 PM
machineman
Status: offline
quote:
ORIGINAL: 359pete
It is not the way to go. You want to lower the guide and not touch the underside of the retainer.
Chris Crossont
A.H.M. Performance
Baltimore, MD
Post #: 20
Login OR Register now to post a reply to this forum topic.
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5570
spectergt2604169
madmikez284156
95slvrz283155
02stangt2988
74454bb2749
cplthomas2545
bluovlh8er2467
blade2300
spartan662250
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
