cam ready
Login | |
cam ready - 3/11/2007 9:05:29 PM
359pete
got my block back from the machine shop. 400 20 over w/ dished pistons. im going with vortec heads for the time being. now its time to make horsepower and torque. will somebody please run some cam and carb ideas by me. would like to reach 350 hp and as much torque as possible. torque is what i really want. going in a 84 Z28 thanks 359PETE
RE: cam ready - 3/11/2007 9:38:39 PM
machineman
You should be in the mid to low 220's (@.050") on the intake duration and about 8-10 degrees higher on the exhaust side. If you can keep the lift below 500 you can do it with a single spring (Z28 style). Run a dual plane like an RPM and either run a 750 vacuum if you are mainly cruising or if you are going to be running the daylights out of it, then go with a 650-700 mechanical carb. Just one engine builder's opinion.
RE: cam ready - 3/13/2007 9:55:31 PM
359pete
thanks machineman, this question i have asked more than once. you are the only person to answer. its very close to the answer i got at the speed shop. what kind of torque might i expect to get out of this set up going w/ a 650 mechanical carb. balllpark figure will do fine. thanks for the help 359 PETE
RE: cam ready - 3/14/2007 11:50:12 AM
rat454
What is your intended use of the engine? Daily driver, street performance, street strip or strip only? What tranny are you using? if auto what stall are you running? What is your rear gear ratio?Posi? G
_____________________________
71 Camaro roller cam 454 LS6 tremec TKO 600 5 speed 2.56 gears,t-top, New Mexico plate "RAT454" 74 Monte Carlo 95 LT1 drive train swap, full computer 77 C10 short step 4x2 454 T-400 hugger orange 496 rwtq 67 Buick Electra 225, 430 tire burner
RE: cam ready - 3/14/2007 10:00:53 PM
359pete
the plan is street strip. mainly a weekend warrior. after the engine i plan to build or rebuild a tranny to accomedate it. thinking 700R4 . i want to be able to cruise without overheating and not get my doors blown off. a rear gear of 3.73. later if all is well a set of dart heads iron eagle platinum . i am on a buget and can only spend what i can get away with.
RE: cam ready - 3/15/2007 12:37:00 PM
rat454
quote:
ORIGINAL: GRIFF Machineman, Nice website and a heck of a nice looking shop. One question regarding the .500 lift on the vortec heads, I have a set we are playing with now I measure .518 inches of travel before the retainer hits the top of the valve seal Ive read where you need .060 inches of clearance to be safe which puts you at .460 of valve lift. How does the Z28 spring help with this situation with the retainer being the issue do you need to change the retainer also. Trim the top of the guide with a pc seal cutter. G
RE: cam ready - 3/15/2007 12:43:11 PM
rat454
quote:
ORIGINAL: 359pete the plan is street strip. mainly a weekend warrior. after the engine i plan to build or rebuild a tranny to accomedate it. thinking 700R4 . i want to be able to cruise without overheating and not get my doors blown off. a rear gear of 3.73. later if all is well a set of dart heads iron eagle platinum . i am on a buget and can only spend what i can get away with. Sounds like a good plan. think I'd stick with a 750 vac sec carb... what ignition are you planning to use? what kind of red line are you looking at on the 400? G
RE: cam ready - 3/20/2007 10:43:29 PM
359pete
this is my breakdown. my block 400 bored 20 over, decked to 9.0" stock crank chamfered oil holes, pistons are dished (compression unknowned) rods balanced. these are the things im stuck with. if anyone can tell me a good way to build torque with this stuff i am unable to change please let me know. i looking for a stock type head for now not set on vortecs just was told that they flow well . had this cam in mind however im told the lift is to much for vortec heads. 224/234 @.050" 465"/488" lift. really want to get it right the first time. a freind at work may have a set of double humps not sure of the #'s would they preform better Please Help ... THANKS 359PETE
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
