Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
What to look for
  Printable Version
Camaro Forum >> Camaro Models >> 4th Generation >> SS / Z28 Camaro >> What to look for Page: [1] 2   next >   >>
Login
Message << Older Topic   Newer Topic >>
What to look for - 10/31/2005 1:13:24 AM
MetallicaRocks
Status: offline
I was thinking about buying an LS1 camaro. I was just wondering what i should look for and what is a realistic price to pay.
Thanks
Post #: 1
RE: What to look for - 10/31/2005 10:32:43 AM
JD1969
Status: offline
JD1969's photo gallery
Try and find an 01-02 they have the better LS6 intake manifold, I would stay away from the 98's (heads are not as good). Other wise they are not really that much different than any other used car. Personally I would want one that is stock or very close, that way any mods you do are done right. As for price an 01-02 car will go for anywhere between $10-17,000 depending on milage. Don't be shy about an LS1 that has 80-90,000 miles, as long as the car has been maintained the engines hold up very well. When i took mine apart with over 70,000 miles on it, the bearings and bores looked new.
_____________________________
2001 SS A4
11.500 @ 116.01
SLP Lid/Granitelli Maf/Fernco/JD1969 custom cat back/UMI Lower Control Arms and PHR/Flowtechs/TSP Cam/Yank 4000 stall
(in reply to MetallicaRocks)
Post #: 2
RE: What to look for - 10/31/2005 12:46:29 PM
MetallicaRocks
Status: offline
Thanks for the help, i just hope i can get the loan now.
(in reply to JD1969)
Post #: 3
RE: What to look for - 10/31/2005 12:52:08 PM
MetallicaRocks
Status: offline
I was also wondering if having t-tops or a convertable changes the handeling of the car.
Post #: 4
RE: What to look for - 10/31/2005 12:55:39 PM
JD1969
Status: offline
Yes the t-top cars and verts are less stiff than the hard tops, but either way you still want sub frame connectors. It's actually pretty hard to find a non t-top car.
2001 SS A4
11.500 @ 116.01
Post #: 5
RE: What to look for - 10/31/2005 5:36:14 PM
MetallicaRocks
Status: offline
what are sub frame conectors? Sway bars and things like that?
Post #: 6
RE: What to look for - 10/31/2005 6:57:52 PM
JD1969
Status: offline
Basicly they are bars that connect the front and rear sub-frames and help to stiffen the chassis.
http://www.spohn.net/category.cfm?categoryid=1080
2001 SS A4
11.500 @ 116.01
Post #: 7
RE: What to look for - 10/31/2005 10:36:48 PM
Hisss04Cobra
Status: offline
Get the t-tops homi...
Post #: 8
RE: What to look for - 12/8/2005 7:31:00 PM
RatedZ
Status: offline
It depends on the year of the LS1 you're looking for. I wouldn't go with a 1998 LS1 because the cylinder walls were thinner than on later LS1s.
I would suggest going with either a 2001 or 2002 LS1 because they had the LS6 intake. The 2001 and 2002 models are holding their value pretty well, but you should be able to find one for about $13,000.
-Dan
1994 Chevrolet B4C Camaro
2005 Subaru Impreza WRX STi
www.topspeedautogroup.com
(in reply to Hisss04Cobra)
Post #: 9
RE: What to look for - 12/8/2005 10:17:49 PM
Lee Willis
Status: offline
We never had any problems with our '98 un til we blew the motor up on maybe the 200th 1/4 mile pass, but then it was modified and producing close to 525 RWHP and lifting the front wheels. it was a great engine even if not as powerful as later models.
the block - thinner cylinder walls? Our block was still fine after the engine blew - we magnifluxed it and it was okay and we sold it to a guy that honed it 3 thousandths and it is still running in another, heavily modified car.
The heads? As far as i know there was no big difference until the Ls-6 heads: all LS1 stock heads are okay, but not really that good.
Things to look for:
1) the rear axle is the Achilles heel on F-bodies. check for leaks around the front seal on the differential, signs of leaks around the rear cover seal. Any noises. These are chronic problem area.
2) Manual Transmission: third gear tends to take abuse in cars that are heavily driven and is usually the first synchro/gear to go. When driving the M-6, check to see that it shifts easily (and fast) inbto third and ffourth. Assume that you face about $900, after you take the trans out of the car and cart it to the reapir shop, to repair it if you feel anything less than perfect action: once you feel resistance here, you have about two months left.
3) Does it have any mods? Check them carefully. Nothing wrong with a modded car (headers, etc.) just more likely to have been abused.
Aston Martin Vantage V8
Lincoln MKZ daily driver
1998 Camaro w. 408/AFR heads, etc.,+NOS street/strip
(in reply to RatedZ)
Post #: 10
Login OR Register now to post a reply to this forum topic.
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5570
spectergt2604169
madmikez284156
95slvrz283155
02stangt2988
74454bb2749
cplthomas2545
bluovlh8er2467
blade2300
spartan662250
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
