RE: TPI running too rich
Login | |
RE: TPI running too rich - 4/3/2007 7:21:19 PM
microkid
Joined: 10/6/2006 From: Gettysburg, PA Status: offline
yea, i dont know what it is, but its setting it into the limp home mode until it warms up. the limp home mode makes it run rich and adjusts the timing so the engine wont kill itself. i dont know what causes it. im sure if i got a trouble code reader i could figure it out
_____________________________
1986 Camaro Z28. Soon to have a mild 350 hp 350 with TPI. Trying to keep it looking factory. Can you say sleeper?
RE: TPI running too rich - 4/3/2007 8:31:49 PM
350rs
Joined: 4/23/2006 From: St. Louis, Missouri Status: online
use the ol paper clip trick... the SES light will flash the code to ya
March 2008 Ride of the Month 89 RS, 60 over 350 crate, 5 speed.
RE: TPI running too rich - 4/3/2007 9:22:00 PM
microkid
ooooo, do tell
RE: TPI running too rich - 4/3/2007 10:40:26 PM
350rs
stick one end of the paper clip in the upper right of your cccs i believe, and the other in the one to the left of it,,, SOMEBODY CORRECT ME IF IM WRONG. The SES will flash, say its code 15, one flash, a pause, then 5 more flashes... it works like this. The first number is obviously the first one to be told, it will flash that many times, then a few seconds of a pause, then it will flash the second number. Im terrible at explinations, so if this is confuseing, dont be suprised, if i were to read over this i would probably kiel over and go into convulsions...
