Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
engine fit question
  Printable Version
Camaro Forums >> Brand Review >> Engine & Internal >> engine fit question Page: [1]
Login
Message << Older Topic   Newer Topic >>
engine fit question - 10/8/2004 10:52:46 AM
89RS_dude
Status: offline
my 89 RS comes with a 305 TBI. How big can i go with out having to get a hood with more room etc?I know i can go 350 but up words of that im not sure. Please let me know..
Post #: 1
RE: engine fit question - 11/18/2004 7:20:52 PM
straightline81
Status: offline
im not shure about ho wuch bigger you could get for the block without messing with the engine mounts, but if you bored and stroked a 350 you could get a 383 no problem
-straightline 81
(in reply to 89RS_dude)
Post #: 2
RE: engine fit question - 12/21/2004 5:12:32 PM
70bigblock
Status: offline
you can fit a big block inside the stock fender wells and hood area without changing anything but the motor mounts, has long has you don't mind losing your air. And then the wiring for the motor. But everything else is the same just a bit taller, also you will need to get big block frontt coil springs to handle the weight.
_____________________________
It maybe slow but its clean and has air!
Any worth having is worth working hard for!!!
Check out my restor project camaro at www.twistedperfektionz.com under apperance/its begun!!
(in reply to straightline81)
Post #: 3
RE: engine fit question - 1/5/2005 2:18:11 AM
Raptorus1
Status: offline
quote:
ORIGINAL: straightline81
-straightline 81
Post #: 4
RE: engine fit question - 1/16/2005 5:06:50 PM
spdshftr
Status: offline
you can get a bb in it but.... you need to beef up the suspension with unibody clips and sub frame connectors first. a bb will tear the car in half.
(in reply to Raptorus1)
Post #: 5
RE: engine fit question - 3/6/2005 10:00:46 AM
chevycamarobadass555
Status: offline
The 400 small block will bolt right up with no probs or hassel.... Make sure u do not buy a high rise intake.... that will cut it pretty close.... If your talking high horsepower and drag racing... Remember the subframe connectors... It doesnt take much to twist those bodys... Been there dont that... My front left tire was about 2 in off the ground.... Also with the high horse power 70bigblock mention front coil springs... dont forget your rear suspnsion... lots of torque and power, you will need stiffer rear suspension but not to much to where ya have no traction....
Drew
(in reply to spdshftr)
Post #: 6
RE: engine fit question - 3/15/2005 1:33:24 PM
70bigblock
Status: offline
Ye aI was just stating that you can put a big block in there. But with that thee is alot of changing too the frame and suspension need to hand not only the weight but also the torque/hp. I been there I twisted a 83 ta with a 383 and a t-5 trans. Oops forget to put in my frame connectors. It is just a matter of what the owner wants in his/her car. If you have the money you can put any motor and trans into any car. It just takes some dead presidents to make it happen.
(in reply to chevycamarobadass555)
Post #: 7
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro >> Brand Review >> Engine & Internal
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5570
spectergt2604169
madmikez284156
95slvrz283155
02stangt2988
74454bb2749
cplthomas2545
bluovlh8er2467
blade2300
spartan662250
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
