Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
RE: accelerator pump
  Printable Version
Camaro >> General >> General Tech >> RE: accelerator pump Page: <<   < prev  1 2 [3] 4   next >   >>
Login
Message << Older Topic   Newer Topic >>
RE: accelerator pump - 4/5/2007 2:46:21 PM
vampyrico
Status: offline
vampyrico's photo gallery
no no no lol. the carb i have is a performance holley rochester model. its a holley built to fit like a rochester. so none of the connectors go back on it, and i am able to tune the air/fuel ratio myself.the 2 screws are on the bottom of the carb. i know this has been done before, im wondering how you get that damn light to go off lol.
(in reply to MadMikeZ28)
Post #: 21
RE: accelerator pump - 4/5/2007 4:58:44 PM
MadMikeZ28
Status: offline
No no no. lol. The original carb that was computer controled had a mixture solenoid for the A/F ratio. The screws only work for idle. The solenoid worked for idle to part throttle. The light wont go out without those hooked up
_____________________________
Its better to burn out than fade away
"Is everyone on DOPE?"
Golden teeth and golden tones, welcome to my presence
(in reply to vampyrico)
Post #: 22
RE: accelerator pump - 4/6/2007 12:51:55 AM
vampyrico
Status: offline
i figured as much, but what does everyone else do that put diff carbs on their car. like if i had gotten the street avenger that day and made it fit by taking the egr valve off and blocking the hole. i would still have those free connectors. what i meant was im sure someone else has done this before. do they just deal with the light, or do they find some kind of bypass? idk. just wondering. the new carb as four screws. 1 for fast idle speed, one for idle speed. 1 for a/f mixture for first 2 barrels. and another screw for the other 2 barrels.
Post #: 23
RE: accelerator pump - 4/6/2007 2:14:16 AM
MadMikeZ28
Status: offline
Get a non computer controled distributer and do away with the puter
other wise your computer is not finding those items and wont work properly. It is most likly running your car in a "limp" mode. Black electrical tape over the light
LOL
Post #: 24
RE: accelerator pump - 4/6/2007 10:50:29 AM
vampyrico
Status: offline
lol, electrical tape. yea, the car feels a little weaker than before. so after tires comes new msd distributor!!  which one should i get i was thinkin bout the hei streetfire. all this aftermarket stuff makes you realize just how much you dont know about cars lol. could you recommend one to me.
Post #: 25
RE: accelerator pump - 4/6/2007 9:46:23 PM
MadMikeZ28
Status: offline
The 8362 (second one down) is inexpensive and you can plug your tach and power wires right into it.
Msd is a good choice I know a guy that buys the accel because they are a few bucks cheaper then they dont work.
Top it off with some MSD super conductor wires. I used those wires for years. Very low resitance and no radio interferance
Post #: 26
RE: accelerator pump - 4/6/2007 10:48:29 PM
vampyrico
Status: offline
cool, would i have to get the msd ignition coil too. cause i planned on the cables and distro. wasnt sure about the coil. i think i should tho.  and i got some yokohamas today.
Post #: 27
RE: accelerator pump - 4/6/2007 11:24:47 PM
MadMikeZ28
Status: offline
http://store.summitracing.com/egnsearch.asp?N=700+4294925143+4294839065+4294881256+400122+4294908216+4294908395+4294840138+115&Nao=0#rstop
Sorry I forgot the link
Oh and I think it comes with a coil
< Message edited by MadMikeZ28 -- 4/6/2007 11:27:15 PM >
Post #: 28
RE: accelerator pump - 4/6/2007 11:48:35 PM
vampyrico
Status: offline
ever installed a distributor? i read it can be difficult. should i get it dont professionally. im not new to tough jobs at all. ive been an aviation maintenance student for since high school (still finishing up) so i should be able to handle it.
Post #: 29
RE: accelerator pump - 4/7/2007 2:01:43 AM
MadMikeZ28
Status: offline
Its not hard to do. You will be pulling one out. Just drop the other one in and make the rotor tip point in the same direction in the same spot. Make note where the distributer base is sitting so the cap will go on and face the same way. Sometimes as you pull the distributer out the oil pump wont turn enough to put it back in so you may have to turn it with a long screwdriver a little bit. Nothing big to do.
Post #: 30
Login OR Register now to post a reply to this forum topic.
Camaro Forum >> General >> General Tech
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5570
spectergt2604169
madmikez284156
95slvrz283155
02stangt2988
74454bb2749
cplthomas2545
bluovlh8er2467
blade2300
spartan662250
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
