RE: MUSTANG TROUBLE
Login | |
RE: MUSTANG TROUBLE - 5/1/2007 1:52:49 PM
LT1RUNNER
Score: 0 Joined: 4/4/2007 Status: online
Ok, best guess. What should I be running at the wheels with... Rebuilt block - stock Edelbrock heads and cam Proform roller rockers 1.5 Computer tune - AZ TPI Bolt on's.... Edelbrock long tube headers 3 inch exhaust with a Flowmaster K&N cold air intake Stock injectors Stock A4 Not sure what the rear gears are. (Haven't looked cause I'm having 3.42 installed once the funds allow.)
RE: MUSTANG TROUBLE - 5/1/2007 8:32:53 PM
94Z28SHAKER
Score: 0 Joined: 7/10/2005 Status: offline
it all depends on the spec#'s on the heads and cam, what kind of timing set, water pump, opti, what kind of rebuild set they used on the block, fuel pump, suspention..ect. pro form roller rockers will work, but i would suggest NSA comp pro mags 1.6, and you'll at least want 28lb injectors. with the stuff you have listed and assuming everything else was stock, and the eldebrock heads/cam are stock/mild hardware, i would say at least 315rwhp 320tq, with 1.6 RR's edit: oh and dont waste your time with the 3.43 gears, get at least a 3.73, you'll be thankful in the long run.
< Message edited by 94Z28SHAKER -- 5/1/2007 8:34:33 PM >
_____________________________
-Any chevy can be an SS, ...but only a camaro can be a Z28 - new top end, stock bottom, A4 consistant 12.5's fastest 12.1
RE: MUSTANG TROUBLE - 5/1/2007 11:49:49 PM
Zoilus
Score: 0 Joined: 3/15/2007 Status: offline
quote:
ORIGINAL: bill12690 sorry to be so blunt zoilus, but holy **** i love your car. Thanks bud, me and the car both appreciate it!! We are up for ROTM, a vote from ya would be cool, especially since the competition is freakin awesome
2002 Z28 here:
