Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
Bruce Griggs “Performance Facts” Chassis
  Printable Version
Camaro Forums >> Brand Review >> Suspension >> Bruce Griggs “Performance Facts” Chassis Page: [1]
Login
Message << Older Topic   Newer Topic >>
Bruce Griggs “Performance Facts” Chassis - 11/16/2005 1:31:29 AM
MMPGuy
Status: offline
John George (Chicane23.com) and Modern Mustang Performance Presents:
Bruce Griggs “Performance Facts” Chassis Seminar
Dispelling the Myths of High-Powered Rear-Drive Chassis Dynamics
Bruce Griggs has over 40 years experience in motorsports, racing, building and modifying
cars that win. His engineering experience and the cars and parts he produces have netted
many victories and championships in a variety of racing venues from SCCA, and NASA to
USAC and NASCAR, as well as daily drivers that ride better than stock yet handle as well as
the best race cars. Although a Road Racing Mustang specialist of late, the subjects he will
discuss applies to all forms of rear drive chassis performance.
Mr. Griggs will present a primer on vehicle dynamics, and concisely explain why his cars
work so well. Admission is $35.00 in advance, and $50.00 at the door. However it is free to
the dealers and owners of GR40 Mustangs. No literature will be supplied. It is
recommended that you take notes if you wish to learn the subject well enough to benefit from
it. The seminar should consume 3 to 4 hours, depending on questions and resulting
discussions.
Preliminary Discussion:
1. General discussion / Chassis stiffening methods. How much is enough?
2. Sprung Mass, Free Body Defined
3. Tire Construction, Slip Angles and Applied Camber
Break for Questions
Volume 1 Geometry and Design:
1. Roll centers, axes, and locations. Where should they be?
2. Anti squat and migration how much is enough?
3. Roll center and migration. How to control?
4. Anti dive. How much is enough?
5. Anti Lift. How much is enough?
Break for Questions
6. Ackerman What is it? How much is enough?
7. Camber pattern and track change
8. Spring rates and wheel rates, progression/digression
9. Roll / Anti-roll
10. Roll couple
11. Roll couple distribution
12. Ride height, importance of. What should it be?
13. Caster vs. Kingpin inclination
14. Steering loading vs. Caster/Kingpin inclination. The importance of corner entry
Break for Questions followed by 30 min Break for Refreshments
Answer questions after break.
Volume 2 Suspension Dynamics
1. Spring rates, discussion on roll couple distribution vs. compliance
2. Anti-roll bar design considerations and effects on roll rates and corner segment.
3. Damping, definitions. Critical Dampening vs. Spring Frequencies. High speed and low
speed damping characteristics
4. Affects of Front Rebound
5. Affects of Front Compression
6. Affects of Rear Rebound
7. Affects of Rear Compression
8. Mountings/Friction/Thermal Characteristics.
Break for Questions
Volume 3 Chassis Loading Variables and there effect on design.
1. Engine Torque TorqueArms, 3 links, 4 links, 5 links, Solid axles vs. IRS. Why the debate?
2. Brake Torque, Camber change, balance, temperature curves, trail braking, left foot braking
3. Over center linkage loadings
4. Transitional loading, and its effects on, slip angles. Understeer/Oversteer and drivability
5. Banking and its effect on roll centers and roll couple
Break for Questions
Volume 4 Tuning the Chassis without data acquisition. When do I adjust what?
1. Ride heights
2. Springs rates, spring splits, progressive spring rates
3. Bars
4. Corner weights
5. Tire pressures
6. Brake effects on chassis tuning
7. Power effects on chassis tuning
8. Typical tuning examples
Questions, Conclude
When: December 10, 2005 @ 11:00 am CST
Where: Modern Mustang Performance
2016 Keller Springs Rd. Suite 126
Carrollton, Texas 75006
To register for this event:
Email: tyreed@airmail.net
Email: chicane23@chicane23.com
Thumbnail Image
Attachment (1)
Post #: 1
RE: Bruce Griggs “Performance Facts” Chassis - 11/16/2005 11:09:31 AM
JD1969
Status: offline
JD1969's photo gallery
WOW if I were anywhere near Texas I would be there in a heartbeat. Griggs knows his stuff for sure.
_____________________________
2001 SS A4
11.500 @ 116.01
SLP Lid/Granitelli Maf/Fernco/JD1969 custom cat back/UMI Lower Control Arms and PHR/Flowtechs/TSP Cam/Yank 4000 stall
(in reply to MMPGuy)
Post #: 2
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro >> Brand Review >> Suspension
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5570
spectergt2604169
madmikez284156
95slvrz283155
02stangt2988
74454bb2749
cplthomas2546
bluovlh8er2467
blade2300
spartan662250
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
