RE: Need help now!!!!!!!!!!
Login | |
RE: Need help now!!!!!!!!!! - 4/11/2007 10:29:50 AM
countryboy
Well no luck. Its still not starting and i pulled the fuel line off goin to the filter and theres no gas comin out. So its the pump i guess. Idk why it would have kicked in all off a sudden and isnt now.
_____________________________
96 camaro rs, Y87 performance package, 1 12in. kicker L7, 4 infinity reference door speakers, and 1000 watt mtx amp. Cold air intake soon.
RE: Need help now!!!!!!!!!! - 4/11/2007 11:02:35 AM
countryboy
I checked at advanced auto and its like $200 for a fuel pump. This website http://www.treperformance.com/FuelPumps/TRE255FuelPumps.html has them for like $70. Can i use the ones on here for my stock 96 rs? I have a chilton manual and it says if you cant hear the fuel pump when u turn the ignition to check the relay and wiring. I have no clue where that is on my car. If any one could help that would be sweet.
RE: Need help now!!!!!!!!!! - 4/12/2007 12:02:04 PM
countryboy
Ok so im really getting frustrated now. I was sure it was the fuel pump that was bad, but then when i went out today i turned the key over and heard the pump going. It started up too but didnt want to idol. Then i couldnt start it again. It seems whenever it sits over night the pump works. I just want to know if it needs a new pump or if not what? Would anything else make it do that? I checked the realy and pulled it out and it seemed fine, i dont think that would be it. PLEASE HELP ME!!!!!!!!!!!!!!!!!!!
RE: Need help now!!!!!!!!!! - 4/13/2007 11:10:18 AM
countryboy
This car always suprises me. I went out this morning to check if it the pump would run agian, and sure enough it did. So i started it up, and it ran alittle rough at first but then was fine. I shut it of and started it agian, and it was fine. After i got back from town, i did the same thing. It seems to be running normal. Idk if it was just some dirt in the pump or what but im not goin to buy a new pump if the car is running. Im just going to put it all back together and see what happens. I'd rather driver it for a month and then take it apart again then replace parts that dont need to be replaced. I'll keep yall posted.
RE: Need help now!!!!!!!!!! - 4/13/2007 1:07:40 PM
cplthomas
Joined: 10/15/2006 From: Upstate NY, stupid Army... Stupid transfer.. Status: offline
Good to hear it is working fine. As I was reading I was trying to fihure out the problem, Sounds like there was either some crud in the line or there might be a wire loose somewhere. If it happens again I would check the electronics.
Urramaich a eorna Land of the free because of the brave. *warning* I dont care about spelling and spell things the way they sound. these -> '''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' <- are my favorite.
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
