Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
Synthetic oil vs regular oil
  Printable Version
Camaro >> Camaro Models >> 3rd Generation >> V8 Tech >> Synthetic oil vs regular oil Page: [1] 2 3   next >   >>
Login
Message << Older Topic   Newer Topic >>
Synthetic oil vs regular oil - 11/22/2005 9:16:45 PM
bootwagner
Status: offline
Is synthetic oil better for a camaro?
Post #: 1
RE: Synthetic oil vs regular oil - 11/23/2005 4:45:22 PM
nj85z28
Status: offline
nj85z28's photo gallery
i would say its better in newer engines from my experiences
_____________________________
New Jersey F-Body Owners Association Member
CamaroForums.com Moderator
PontiacTalk.com Moderator
ClubGP Member #22259
(in reply to bootwagner)
Post #: 2
RE: Synthetic oil vs regular oil - 11/25/2005 7:33:11 PM
RatedZ
Status: offline
167,500 miles on a 1994 LT1. I've never used anything but conventional oil in ANY of my cars, and have NEVER had a problem. On my current car, which has run on nothing but 5W30 or 10W30, no ticks, no tocks, no smoke on start-up, no burning oil, no eating oil either.
Post #: 3
RE: Synthetic oil vs regular oil - 11/25/2005 8:38:54 PM
TimmyTheWop89
Status: offline
TimmyTheWop89's photo gallery
you know why? cuz you have a chevy small-block, the best production motor ever. i watched that discovery show mythbusters, you dont wanna know what they put in a chevy small blocks gas tank, but it kept chuggin the whole way.
(in reply to RatedZ)
Post #: 4
RE: Synthetic oil vs regular oil - 11/25/2005 11:44:03 PM
RatedZ
Status: offline
quote:
ORIGINAL: TimmyTheWop89
Yeah, I saw that. That motor just would not die.
(in reply to TimmyTheWop89)
Post #: 5
RE: Synthetic oil vs regular oil - 1/6/2006 5:51:39 PM
JLT25
Status: offline
USE REGULAR OIL TO BREAK IN A MOTOR, THEN CHANGE TO SYNTHETIC. SYNTHETIC IS A BETTER OIL, IT WITHSTANDS HIGHER TEMPERATURES THAN REGULAR OIL.
Post #: 6
RE: Synthetic oil vs regular oil - 1/6/2006 7:14:45 PM
Lee Willis
Status: offline
Its better for any car in just about every way. If you car is older get a thicker grade.
Aston Martin Vantage V8
Lincoln MKZ daily driver
1998 Camaro w. 408/AFR heads, etc.,+NOS street/strip
(in reply to JLT25)
Post #: 7
RE: Synthetic oil vs regular oil - 1/9/2006 2:46:23 AM
v8chvyguy
Status: offline
v8chvyguy's photo gallery
If you don't mind the drop in oil pressure. I would only recomend synthetics be used just after break in. don't forget that brand new car you just bought w/65 miles on it, that motor ain't broke in yet. putting it in a motor with 75K plus on the odo is as pointless as using Maxlife in a 100K mile leaking grease ball. You wont see any benefit from it cause the motor was'nt conditioned to run it. all you'll do is lower the oil press. and increase the risk of breaching the hydrodynamic barrier formed between your bearings and crank. Not to mention the cost. All the tests I've seen were performed on new engines not 100K mile plus, hard run motors. I'm not saying synthetics are all hype they are better than convetional oils, and when implemented at the right time they will extend the life of your investment.They can talk friction modifiers all they want, I suggest looking up "Oil film and wedge principal". that plays a key part in an older motor with more bearing clearance than new. Who cares about how high a temp it can take? If your engine produces so much heat that you need an oil thats good to 800 degrees you have a bigger problem.
DON'T CRUSH'EM...RESTORE'EM!
(in reply to Lee Willis)
Post #: 8
RE: Synthetic oil vs regular oil - 1/10/2006 5:47:40 PM
gmpartsguy
Status: offline
Also don't switch to synthetics in an old motor. Seals worn in to conventional oil won't be able to stop the smaller molicules of synthethic oil from slipping by. Usually only happens on motors with 100k miles or more.
(in reply to v8chvyguy)
Post #: 9
RE: Synthetic oil vs regular oil - 1/11/2006 11:57:50 PM
v8chvyguy
Status: offline
thanx gmpartsguy, I forgot about that one.
(in reply to gmpartsguy)
Post #: 10
Login OR Register now to post a reply to this forum topic.
Camaro Forums >> Camaro Models >> 3rd Generation >> V8 Tech
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5573
spectergt2604207
madmikez284175
95slvrz283155
02stangt2992
74454bb2749
cplthomas2551
bluovlh8er2469
blade2300
spartan662255
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
