Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
2.8L v6 bad acceleration!!!
  Printable Version
Camaro >> Camaro Models >> 3rd Generation >> V6 Tech >> 2.8L v6 bad acceleration!!! Page: [1] 2   next >   >>
Login
Message << Older Topic   Newer Topic >>
2.8L v6 bad acceleration!!! - 4/20/2007 2:51:57 AM
ReeceDawg
Score: 0
Status: offline
okay. heres the deal, ive got an 88 camaro with a 2.8L v6. the engine idles smoothly and at high speeds runs smoothly.. but on hard accelertaion it will bog and shake and i will go nowhere!!. ive changed spark plugs, wires, fuel filter. I have no cat so it cant be clogged. when the engine is cold ( say sitting for 5 hrs) it will run strong and wont bog out on me.. but once it heats up( a min or two) the accleration will drop and the old problems will resume. Ive asked others and theyve suggested fuel filter, change cat etc. IM STUCK and dont know waht to do next!!
any info or suggestions would be greatly appreciated!! thanks guys
Post #: 1
RE: 2.8L v6 bad acceleration!!! - 4/20/2007 1:58:53 PM
z28pete
Score: 0
Status: online
z28pete's photo gallery
If it sicarbed it is probably a carb problem. If it is injected, it appears that it runs bad when it goes into closed loop. Probably one of the sensors. Is the check engine lite coming on?
< Message edited by z28pete -- 4/20/2007 2:00:58 PM >
_____________________________
Pete
(in reply to ReeceDawg)
Post #: 2
RE: 2.8L v6 bad acceleration!!! - 4/20/2007 3:26:36 PM
MadMikeZ28
Score: 0
Status: online
What Pete said about when it gets warm..
You have multi port???
Its better to burn out than fade away
"Is everyone on DOPE?"
Golden teeth and golden tones, welcome to my presence
(in reply to z28pete)
Post #: 3
RE: 2.8L v6 bad acceleration!!! - 4/20/2007 6:21:01 PM
ReeceDawg
Score: 0
Status: offline
yeah its a multi port injection. the light  isnt on, but the guy before me might have took it out for selling, also there is no OBD of any kind. the plug in is there but no signal comes out of it. he might have monkeyd with things.
(in reply to MadMikeZ28)
Post #: 4
RE: 2.8L v6 bad acceleration!!! - 4/20/2007 6:38:36 PM
MadMikeZ28
Score: 0
Status: online
Does a check engine light come on as you first turn the key on? Have you used a code reader or paper clip in the a+b on the data link connector?
Post #: 5
RE: 2.8L v6 bad acceleration!!! - 4/20/2007 7:18:27 PM
ReeceDawg
Score: 0
Status: offline
no, only lights that come on are parking break and seatbelts when i turn it on. Ive used a code reader and the a+b on the data link.
Post #: 6
RE: 2.8L v6 bad acceleration!!! - 4/21/2007 1:26:49 AM
MadMikeZ28
Score: 0
Status: online
No light. Either its burned out or like you say monkeyed! The code reader has a screen and does it show code 12? This should always come up when its in diagnostic mode.
Post #: 7
RE: 2.8L v6 bad acceleration!!! - 4/21/2007 11:10:26 PM
ReeceDawg
Score: 0
Status: offline
well we stuck the code reader in and nothing came up at all. we had the right chip for it and all that jazz but when we would go to read codes it would say please turn on your ignition etc. and we even turned the engine on and tried live diagnostics but it was like the plug was completely dead. so i guess the plug is a dud and goes to nothing maybe. and when we jumped the a+b connectors with a cotter pin, no dash lights came up whatsoever.
Post #: 8
RE: 2.8L v6 bad acceleration!!! - 4/22/2007 1:16:34 AM
MadMikeZ28
Score: 0
Status: online
There is a light driver. Its in a small odd shaped box about the size of a match box near the computer. Its for the Check engine light but I am not sure as to how it works. Never had problems with any. It may be damaged though
Post #: 9
RE: 2.8L v6 bad acceleration!!! - 4/22/2007 2:11:26 AM
sewerrat
Score: 0
Status: offline
Reecedawg, is the code reader you're using the simple plug-in type or with a built in display screen? If your check eng. light in the dash isn't working then the basic plug in with no screen won't do you any good.  I had a similar problem last year with my 88 2.8 with stumbling on acceleration. It was the mass air sensor but my check eng. is working. Try driving the vehicle with the MAF unplugged, see if that makes a difference.
Post #: 10
Login OR Register now to post a reply to this forum topic.
Camaro Forums >> Camaro Models >> 3rd Generation >> V6 Tech
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604220
madmikez284186
95slvrz283155
02stangt3006
74454bb2749
cplthomas2556
bluovlh8er2469
blade2300
spartan662261
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
