Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
RE: Choke Warning Light
  Printable Version
Camaro Forum >> Camaro Models >> 3rd Generation >> V6 Tech >> RE: Choke Warning Light Page: <<   < prev  1 [2]
Login
Message << Older Topic   Newer Topic >>
RE: Choke Warning Light - 4/23/2007 2:04:25 PM
Gotenkusu10022
Score: 0
Status: offline
Yeah, it's factory carbed. Upon removal of the M/C solenoid, I found a cracked o-ring on the tip. I'll see about replacing that o-ring, then I'll check for any vacuum leaks.
(in reply to cplthomas)
Post #: 11
RE: Choke Warning Light - 4/23/2007 2:28:13 PM
MadMikeZ28
Score: 0
Status: online
I will get that flow chart scanned and sent to you so you can test the m/c
cplthomas
Off topic but I get your humor. Its like the stuff I see in Uncle Johns bathroom readers.
Here is one from one of thier books.
"Half of all crimes are commitedby people under the age of 18"
"Most dangerous animal in Ireland, The Bumblebee"
_____________________________
Its better to burn out than fade away
"Is everyone on DOPE?"
Golden teeth and golden tones, welcome to my presence
(in reply to Gotenkusu10022)
Post #: 12
RE: Choke Warning Light - 5/11/2007 4:21:07 PM
vzfox
Score: 0
Status: offline
I have the exact same car....engine and carb.  And I also have "kinda" the same problem.  I purchased a new elect. thermostat for my choke because the choke light wouldnt go out, but the car seemed to run pretty decently.  After putting the new thermostat in, I realized that I wasted my money.....it did nothing.  With the car cold, the choke plate will close and the car will have a normal fast idle...as it gets warm/hot the choke plate will not open and the car continues to fast idle.  If you press the gas pedal with the car hot, the choke plate cause's it to starve for air.
Ok....here is my "jerry riggin" fix.......I found that if I take the choke thermostat out of the carb, with the wire connected, the choke light goes out.  But as soon as you touch it to the carb, it lights back up.  Me being the "master rigger" that I am, I put some elect black tape around the thermostat, keeping it from making an electrical contact with the carb.  After placing the thermo back in the carb......problem solved, well kinda anyways.....the choke light will flicker from time to time.
If I unplug the choke thermo wire and turn the ignition on, it has 12 volts and stays that way.  If I plug the wire in (without my elect tape fix) it would only read 2 volts with the ignition on, causing the choke not to heat up enough to open fully.  At least now it gets the voltage it needs to heat up and open, but just havent gotten the choke light thing totally figured out.
Post #: 13
Login OR Register now to post a reply to this forum topic.
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604220
madmikez284185
95slvrz283155
02stangt3006
74454bb2749
cplthomas2556
bluovlh8er2469
blade2300
spartan662261
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
