Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
cam shaft upgrade
  Printable Version
Camaro Forum >> Camaro Models >> 3rd Generation >> V8 Tech >> cam shaft upgrade Page: [1]
Login
Message << Older Topic   Newer Topic >>
cam shaft upgrade - 4/23/2007 2:04:45 AM
vampyrico
Status: offline
vampyrico's photo gallery
    ive been thinkin bout a new cam. what do i need to keep in mind when doing this. what kind of cam would be ideal for me. im not looking to race the car on a track, or street for that matter. its a 1985 camaro 305. what brands are best, is that edelbrock cam any good. what kind of lifters do i have. ive never done this before, but im not a noob to engines. ive torn down a few turbine engines. i know its diff, but im sure its alot harder and alot more specs to maintain. lol.
id also like to put a few other bolt on mods on the camaro. headers, intake manifold. things of that nature, and do more internal workings later. what do you all reccommend. i have a holley carb already. and a 4.5in exhaust from the cat back. will be getting a MSD hei streetfire sometime soon(to get rid of computer). umm. as far as emissions go, i live in virginia, im told that the only real emissions control i need it a catalytic converter, and i want to change that for a high flow cat. but all the other emissions stuff can be axed. so any input will be greatly appreciated.
< Message edited by vampyrico -- 4/23/2007 2:19:25 AM >
_____________________________
Post #: 1
RE: cam shaft upgrade - 4/25/2007 9:47:13 AM
uradumass5695
Status: offline
If your going to do headers, an intake manifold, and a cam, i would go with edelbrock for the intake and cam. Get a performer eps intake manifold http://store.summitracing.com/partdetail.asp?part=EDL%2D2701&autoview=sku
For your cam: http://store.summitracing.com/partdetail.asp?part=EDL%2D2102&autoview=sku
For your headers: http://store.summitracing.com/partdetail.asp?part=BIG-16102FLT
And those headers are emissions legal so you will be ok. Im putting those headers on my 350 thats why i showed you them they are the best headers for the money. Good luck with your project though. Oh and i would get some nice lookin valve covers as well because you have to take the old ones off to do the lifters. Good luck
(in reply to vampyrico)
Post #: 2
RE: cam shaft upgrade - 4/28/2007 3:15:55 AM
vampyrico
Status: offline
thx for the suggestions, i appreciate it. thats the same manifold i was lookin at. i was unsure about the cam and the headers.
(in reply to uradumass5695)
Post #: 3
RE: cam shaft upgrade - 4/30/2007 2:53:11 AM
vampyrico
Status: offline
since im changing the cam shaft. there are a few things i have to take off. chain, gear, intake manifold, possibly any rods.
was thinking this for gears and chain. good enough? should i go more expensive or will cheaper be alright. good brand?
http://store.summitracing.com/partdetail.asp?part=CLO%2D9%2D3500TX9&autoview=sku
for my cam
manifold
am i right in thinking it would be wise to just change all this at once since i have to take it off anyway.
maybe a dressup kit for everything else.
input please
also,would it be better to remove the engine from the bay to do all this or is it possible just more difficult to do it while installed in the car. i dont have a lift, so that means i would have to borrow one if i have to take it out. but if i cant just take off the front end and it be easy all the same, im all for it.
< Message edited by vampyrico -- 4/30/2007 2:55:09 AM >
Post #: 4
RE: cam shaft upgrade - 5/2/2007 4:17:06 AM
vampyrico
Status: offline
bump
Post #: 5
RE: cam shaft upgrade - 5/2/2007 5:26:27 AM
74454bb
Status: offline
74454bb's photo gallery
Didn't see this one, yeah those are good choices, if you can have a shop do it so they can tune your car to get the most out of it.
www.horsepowerforums.org
www.carsbySS.com
www.blueprintengines.com
Post #: 6
RE: cam shaft upgrade - 5/3/2007 2:16:15 AM
vampyrico
Status: offline
a guy i know said i should buy an engine from a junk yard and put all the parts i want in it, that way i have the car to drive and an engine thats easy to work on. while this sounds like a great solution to one problem, it seems unnecessary and problematic in itself because 1. i have another vehicle to get me around while the camaro is parked. and 2 being that i dont have a proper space for an engine to hang around at on stand. also it wouldnt be cost efficient or timely to have an engine sit out back with a tarp over it for months until i put everything in it and it would be a setback in itself because i would have to buy an engine and a stand. 150 for the engine and maybe 60 for the stand. now, im not sure what i should do. while option 1: (driving my second vehile while working on the camaro) is a good idea, option 2: (buying an engine and stand to work on) is also a good idea. one has more of a financial setback. or should i look at it as an investment. which would you all do?
the other prob i have with new engine idea is i didnt plan on putting a new engine is. think its stupid to have 2 305s. i wanted to put a larger engine in it. but if i do that i would need to change so many other things. driveshaft, tranny, rear end. etc etc. all things that would be better done in a garage, not a driveway. althought if i had 5 grand i could do it all in my driveway this summer lol. i dont have 5 grand.  anyway, help me decide. and none of that "its up to you stuff" i know that. just help me make sense of all of it, and reason.
(in reply to 74454bb)
Post #: 7
RE: cam shaft upgrade - 7/18/2008 9:03:40 AM
Z28Reggie
Status: offline
Well if you go with a 350 you dont have to change all of that stuff I pretty sure the trans and drivetrain even the ecu will work And you can get a chip for it thats if you not trying to go big block or anything. 2 305s is a bad idea i dont like them to start and you cant get much out of them but just driving one car and working on the camaro sounds more sensible to me anyway Well hope you figure it all out Good luck
Post #: 8
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604220
madmikez284186
95slvrz283155
02stangt3006
74454bb2749
cplthomas2556
bluovlh8er2469
blade2300
spartan662261
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
