Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
BW Super T-10 Trans Problem
  Printable Version
Camaro >> Camaro Models >> 2nd Generation >> V8 Tech >> BW Super T-10 Trans Problem Page: [1]
Login
Message << Older Topic   Newer Topic >>
BW Super T-10 Trans Problem - 4/23/2007 4:26:53 PM
johnb1973
Score: 0
Status: offline
Anyone know how to align a Borg Warner Super T-10 transmission with the shifter outside of continual trial and error???
I have a 78 Z28 with original Super T-10 transmission, but someone changed the shifter to Hurst.  The shifter and trans worked well together prior to being pulled.  I pulled the trans to fix several bad leaks but now it only wants to run in reverse, and will not go into neutral.  In any forward gear, the engine will die even if I rev it and try to ease out on the clutch.
I found instructions in my 78 Chevy manual for neutral alignment directions for 78 Vette with a 4-speed, but it is different from the Super T-10.
Post #: 1
RE: BW Super T-10 Trans Problem - 4/24/2007 2:16:09 AM
uncle bill
Score: 0
Status: offline
It's the same basic approach on the super T10 or muncie. There is a slot in the center of the shifter body that you have to run a pin through with the trans in neutral. Only then can you adjust it. Try hurst online for instructions.
(in reply to johnb1973)
Post #: 2
RE: BW Super T-10 Trans Problem - 4/26/2007 1:46:42 PM
johnb1973
Score: 0
Status: offline
thanx
Post #: 3
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro Forums >> Camaro Models >> 2nd Generation >> V8 Tech
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604220
madmikez284186
95slvrz283155
02stangt3006
74454bb2749
cplthomas2556
bluovlh8er2469
blade2300
spartan662261
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
