Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
Weird Noise out of Front End
  Printable Version
Camaro >> Brand Review >> Suspension >> Weird Noise out of Front End Page: [1]
Login
Message << Older Topic   Newer Topic >>
Weird Noise out of Front End - 4/26/2007 4:27:47 PM
silverdoor
Status: offline
Hi guys, i was wondering if anyone could help me.  I have been trying to fix a knocking sound that is coming from somewhere in my front end since i replaced the struts.  It happens when i rock the steering wheel back and forth and also when i hit bumps.  It is kinda loud and sounds like metal on metal.  I have been to 4 different shops and have replaced the upper control arm ball joint, both tie rod ends, the strut twice and have run out of ideas.  Any help would be great!  It is a 94 camaro v6 with the 3.4 if that helps at all.  Thanks for looking!
Post #: 1
RE: Weird Noise out of Front End - 4/26/2007 7:07:11 PM
z28pete
Status: online
z28pete's photo gallery
Check the steering rack mounting, make sure it tight and not moving side to side, and check the sway bar bushings & links. Put car on a lift and have someone move the steering wheel and go under the car &try to pin down where the noise is coming from.
< Message edited by z28pete -- 4/26/2007 7:08:36 PM >
_____________________________
Pete
(in reply to silverdoor)
Post #: 2
RE: Weird Noise out of Front End - 4/26/2007 7:53:09 PM
silverdoor
Status: offline
last time i had it on a jack, the sound was comin from the inner tie rod end where it connects to the steering gear.  thats why i replaced that tie rod end and figured it would help but the steering gear was still a little loose so im not sure if that is the problem or not.  ill check the sway bar bushings next.  Thanks for your help!
(in reply to z28pete)
Post #: 3
RE: Weird Noise out of Front End - 6/1/2007 6:35:02 AM
berlinettalover
Status: offline
berlinettalover's photo gallery
I have the same noise and i just did the links ont he sway bar and i am still getting the noise...Tie rods and everything else seems fine and the steering rack is tight on the car....I am out of ideas as well...and it happened as soon as i replaced my struts as well.
--NOS is like a hot chick with an STD, you wanna hit it but you're scared of the consequences--
Lost Prophets "Dark Angel"
Post #: 4
RE: Weird Noise out of Front End - 6/1/2007 8:04:08 AM
1969 SS
Status: offline
I have encountered this problem you describe in the past, on others cars. it totally sounds like a bushing problem, not a hard suspension part problem. I totally forget which bushing went bad, but I do remember when I had them turn the wheel (let's say if I was on the passenger side of the car, I had them turn it left and the opposite for the driver's side) I could look behind the tire and see what went bad without even looking at the car
sorry I couldn't help you out more as my memory isn't too good sometimes
another longshot and one that's not easily noticed, and might be easy to do, is if your car has a front swaybar and they had to disconnect it to install your struts. they could have quite possibly installed your swaybar endlinks backwards.
I just try to do, what I can do, when I can do it
http://www.myspace.com/northeast_rod_run/
(in reply to berlinettalover)
Post #: 5
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro Forum >> Brand Review >> Suspension
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604220
madmikez284186
95slvrz283155
02stangt3006
74454bb2749
cplthomas2556
bluovlh8er2469
blade2300
spartan662261
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
