Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
tap tap tap hope there isn't a crack
  Printable Version
Camaro Forums >> Camaro Models >> 3rd Generation >> V8 Tech >> tap tap tap hope there isn't a crack Page: [1]
Login
Message << Older Topic   Newer Topic >>
tap tap tap hope there isn't a crack - 4/29/2007 5:47:45 PM
zachyfarms
Status: offline
Just baught 84 z28 with 305... before buying i noticed a tapping noise but one that sounded to be a simple thing... after driving 200 miles home i checked things out found all the driver side spark plugs to be very loose hand turn loose i figured that was the noise i was hearing( great yeah). nope it is definately drivers side 1 and 3 cylander area.  can an exhaust gasket blow and make a noise that almost sounds like valve tapping??? i know i may be stretching that one but im wishing for something simple.. if i have the car in park and rev it, it doesn't or barely taps it only when under load that it taps.... any suggestions... ,
Post #: 1
RE: tap tap tap hope there isn't a crack - 4/29/2007 6:08:56 PM
74454bb
Status: offline
74454bb's photo gallery
Could be an exhaust manifold gasket. they make a tapping sound when they blow.
_____________________________
www.horsepowerforums.org
www.carsbySS.com
www.blueprintengines.com
(in reply to zachyfarms)
Post #: 2
RE: tap tap tap hope there isn't a crack - 4/29/2007 11:08:24 PM
94Z28SHAKER
Status: offline
94Z28SHAKER's photo gallery
either that or a loose rocker nut, if its still there after you change the gasket, take off the rocker covers and find the tap, tighten the rocker nut slightly until the tap goes away, should only take 1/8th of a turn, if that,  so dont go crazy tightening them, do it cautiously, and good luck.
ps. if its still there after all that, you may have any number of bad things wrong in the bottom end of the motor.
-Any chevy can be an SS,
...but only a camaro can be a Z28 -
new top end, stock bottom, A4 consistant 12.5's fastest 12.1
(in reply to 74454bb)
Post #: 3
RE: tap tap tap hope there isn't a crack - 4/29/2007 11:27:17 PM
GRIFF
Status: online
GRIFF's photo gallery
Does it make the noise at idle? Did you try higher octane fuel?
(in reply to 94Z28SHAKER)
Post #: 4
RE: tap tap tap hope there isn't a crack - 4/30/2007 12:22:21 AM
MadMikeZ28
Status: online
You may find that there are no gaskets on the exhaust manifolds. Sometimes the factory never put them in there. It could also be a cracked exhaust manifold. It may be broke under the shield for the heat riser tube. Look around and see if there are any blackened areas from exhaust leaks
Its better to burn out than fade away
"Is everyone on DOPE?"
Golden teeth and golden tones, welcome to my presence
(in reply to GRIFF)
Post #: 5
RE: tap tap tap hope there isn't a crack - 5/2/2007 7:00:48 PM
zachyfarms
Status: offline
Thanks for the help noise is gone and i performed both process on the engine it runs a lot better too.
Size does matter fat chicks take atleast 50 to 70 HP
(in reply to MadMikeZ28)
Post #: 6
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro >> Camaro Models >> 3rd Generation >> V8 Tech
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5575
spectergt2604220
madmikez284186
95slvrz283155
02stangt3006
74454bb2749
cplthomas2556
bluovlh8er2469
blade2300
spartan662261
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
