Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
whats the difference in NOS
  Printable Version
Camaro Forums >> Brand Review >> Nitrous, Super Chargers, & Turbos >> whats the difference in NOS Page: [1] 2   next >   >>
Login
Message << Older Topic   Newer Topic >>
whats the difference in NOS - 5/30/2007 9:59:28 PM
nkramirez7
Status: offline
with Dry and Wet...whats better?  I have a 2000 v6 camaro
Post #: 1
RE: whats the difference in NOS - 6/1/2007 8:37:58 PM
nickdotcom
Status: offline
dry uses your computer to add more fuel
wet injects fuel with the nitrous
better is a matter of opinion
_____________________________
(in reply to nkramirez7)
Post #: 2
RE: whats the difference in NOS - 6/1/2007 9:30:31 PM
badinfluenceRS
Status: offline
dry kit's also inject nitrous into the fuel system (just to clarify)
I was told a dry kit would be easier to install
1999 Camaro Z28 - LS1 / A4
(in reply to nickdotcom)
Post #: 3
RE: whats the difference in NOS - 6/1/2007 11:27:00 PM
nkramirez7
Status: offline
but what would be easier on the engine?
(in reply to badinfluenceRS)
Post #: 4
RE: whats the difference in NOS - 6/2/2007 7:07:09 AM
badinfluenceRS
Status: offline
I'm sure there is not a great difference between the two....
I was TOLD that a wet kit would be a little safer, just going of what i've heard
Post #: 5
RE: whats the difference in NOS - 6/2/2007 1:15:28 PM
nickdotcom
Status: offline
depends on what size shot you want
when i did the research for nitrous i decided to go wet
im just a kid by most of yalls standards and the install was very easy, the wiring was the hardest part and it wasn't even that bad. i was triple checking all my connections so it was a bit time consuming.
Post #: 6
RE: whats the difference in NOS - 6/2/2007 8:04:37 PM
nkramirez7
Status: offline
ok cool thanks, i appreciate the info
Post #: 7
RE: whats the difference in NOS - 6/6/2007 5:46:11 AM
CamaroKid16
Status: offline
CamaroKid16's photo gallery
Wet nitrous systems will be alil more difficult, but you can get pretty much any amount of power you want out of it. In the v6... dry would be sufficent, just because you're never going to want to go over 150 EVER!! I'm choosing to go with the dry and put about 75 shot in.The install... pretty easy, just follow instructions!
Post #: 8
RE: whats the difference in NOS - 6/6/2007 3:07:44 PM
Lee Willis
Status: offline
quote:
ORIGINAL: badinfluenceRS
Really, I've installed and fiddled with dozens of dry kits and never seen one that does anything, much less "injects" NOS or anything else into the fuel system. A dry kit injects the NOS gas into the incoming air somewhere upstream of the MAF so that the NOS, mixed with the incoming air, is measured by the MAF, and the additional mass is interpreted as more air, and thus results in the ECM injecting additional fuel.  It works well when you are trying to add no more than about 33% additional power from the NOS, after than injection spray duration and other factors make it best to go to a wet kit, which squirts fuel into the intake manifold near the ports while also shooting NOS into the intake manifold.
Dry kits are a big advantage because:
a) they are cheaper and easier to install, you don't have to do a thing to the fuel system - just leave it alone: fewer parts to install, less time to install.
b) they are safer: the additional fuel lines, pumps and fuel injectors of a wet system often leak and start fires
c) they are easier to tune: wet kits can take 2 to 3 times the dyno time to get perfect A/F ratio and no ECM back-off ocsillations
d) they are easier to hide: a lot of street racers hide the system so they can claim they have no NOS and even open the hood to prove it.  I've done it myself.
Aston Martin Vantage V8
Lincoln MKZ daily driver
1998 Camaro w. 408/AFR heads, etc.,+NOS street/strip
Post #: 9
RE: whats the difference in NOS - 6/9/2007 12:46:19 PM
CamaroKid16
Status: offline
LEE pretty much took care of it all. Nice info LEE!!!
[image]http://s237.photobucket.com/albums/ff142/Camarokid16/?action=view¤t=Carandlegopictures005.jpg[/image]
1994, 3.4, 5-speed, 32mm front swaybar and 25mm rear, kyb agx adj struts/shocks, strut bar, eibach pro kits, Lakewood adj. panhard bar.
(in reply to Lee Willis)
Post #: 10
Login OR Register now to post a reply to this forum topic.
Camaro >> Brand Review >> Nitrous, Super Chargers, & Turbos
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5570
spectergt2604173
madmikez284156
95slvrz283155
02stangt2989
74454bb2749
cplthomas2546
bluovlh8er2467
blade2300
spartan662250
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
