Mallory Ignition
Login | |
Mallory Ignition - 6/3/2007 1:53:53 PM
69RS350
Score: 0 Joined: 4/21/2007 Status: offline
Mallory ignition said I needed a resistor hooked into the distributor. Does anyone know if a 69 RS Camaro had a resistor wire already in it at stock?
RE: Mallory Ignition - 6/3/2007 3:50:27 PM
z28pete
Score: 0 Joined: 8/7/2005 Status: offline
In those days I believe they still used a large ceramic resistors instead of a resistance wire to drop the voltage to the points so as to keep them from burning up. Are you using a Mallory distributor with points, or an electronic one? They need to be wired slightly differently.
< Message edited by z28pete -- 6/3/2007 3:55:20 PM >
_____________________________
Pete
RE: Mallory Ignition - 6/3/2007 5:24:36 PM
69RS350
It is a electronic, with a saparate coil.
RE: Mallory Ignition - 6/29/2007 10:48:00 PM
Jesse7071
Score: 0 Joined: 6/29/2007 Status: offline
GM used a resistor wire on that car. It will be located on the engine side of the firewall, coming out of the aire pass through connector below the master cylinder. The resistor wire is unlike any of the other wires, it has light brown cloth insulation, instead of colored rubber. If you are using an electronic ignition, you need to unplug the pass through connector, remove the resisior wire (including the metal pin/terminal) from the connector, and either get the pin off the wire, or buy another GM pin. Then crimp a regular piece of automotive wire to the pin and clip it back in place. Plug the pass through back in, and you will now have 12 v at that wire. Instead of 9v
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Camaro Prices
Chevy Camaro
Camaro concept car
1969 Camaro
Advertising Info
Contact Us |
Advertising |
CamaroForums.com Partners |
Camaro Links |
Archive |
About Us |
Link To Us |
Legal |
Privacy Policy |
© Camaro Forums
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
