Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
RE: Just got a camaro... 400hp?
  Printable Version
Camaro Forums >> Camaro Models >> 4th Generation >> SS / Z28 Camaro >> RE: Just got a camaro... 400hp? Page: <<   < prev  1 [2] 3   next >   >>
Login
Message << Older Topic   Newer Topic >>
RE: Just got a camaro... 400hp? - 6/12/2007 6:59:45 PM
o2camaross
Status: offline
magnaflow with long tubes is a great setup, you wont be dissapointed.  Get all the bolt ons first the consider heads and cam swap, since you're not a big fan of nitrous.
_____________________________
02 camaro SS LE # 2777
slp lid, k&n filter
Flowtech, ORY, and magnaflow catback
BMR subfame connectors, torque arm, PHR, LCA, STB, anti-squat brackets, spohn swaybars
Eibach Pro springs, Bilstein shocks
pro 5.0 short throw shift, TR224 and tun
(in reply to jdgates11)
Post #: 11
RE: Just got a camaro... 400hp? - 6/13/2007 2:08:56 PM
Big_Bird_1985
Status: offline
The reason I said nitrous is bad if you spray it alot is because. By spraying nitrous you increase pressure inside your car, burns hotter, and can and will burn your piston rings valves, etc. Granted if your motor is built for it then you won't have these problems, 9 times out of 10 though people just slap in on there and spray away. I do have experience with nitrous my dads car had nitrous...it blew up, a friend of mine from works 5.0 caught on fire, and a friend of mine got killed spraying nitrous on his car. All my experiences with it are negative. But yes it is personal preference I agree with slvrZ28 in that racing all motor and winning is more gratifying than spraying nitrous to win.
02 SS Lontube headers, air lid, no cat exhaust, drag radials, and 3.90:1 gear ratio
(in reply to o2camaross)
Post #: 12
RE: Just got a camaro... 400hp? - 6/13/2007 4:18:24 PM
JD1969
Status: offline
JD1969's photo gallery
Actually nitrous will not hurt the car anymore than adding power in other ways. AS LONG AS you stay within the safe limits of your engine. Anytime we add power to our engines we increase cyclinder pressure, or add more air and fuel, it's a pretty simple concept. Nitrous just do this in a much more efficiant and quicker manner. On a stock motor a 100 shot is pefectly safe, as long as all precuations are taken. Just because I am curious, how did your friend get killed by using nitrous?
2001 SS A4
11.500 @ 116.01
SLP Lid/Granitelli Maf/Fernco/JD1969 custom cat back/UMI Lower Control Arms and PHR/Flowtechs/TSP Cam/Yank 4000 stall
(in reply to Big_Bird_1985)
Post #: 13
RE: Just got a camaro... 400hp? - 6/13/2007 5:40:55 PM
nickdotcom
Status: offline
granted that using nitrous will cause more wear and tear on the engine than not using it, but any power adder will do this.
and how did the 5.0 catch fire? nitrous is non-flammable. it breaks into oxygen and nitrogen at around 600 degrees....
and trust me, it feels just as good to win with nitrous as without it. how would you know if you've never sprayed?
its sounds like all the people you know of that have used nitrous used it incorrectly
(in reply to JD1969)
Post #: 14
RE: Just got a camaro... 400hp? - 6/13/2007 8:04:23 PM
coprunr
Status: offline
coprunr's photo gallery
according to NOS (yes the company) a bone stock V8 can handle a 140 even with cast pistons...i would love to put a bottle on my car until i can get the funds to do the LT4 conversion
as i walk through the valley of rice
i shall fear no import
for i know torque is with me
(in reply to nickdotcom)
Post #: 15
RE: Just got a camaro... 400hp? - 6/13/2007 8:19:21 PM
95slvrZ28
Caretaker of the Ban Hamster
Status: offline
95slvrZ28's photo gallery
quote:
ORIGINAL: nickdotcom
Nope, Oxygen isn't flamable at all
And I also contest that my full exhaust has caused no more stress on the engine than if the exhaust and intake were still stock...I would also like to note that purchasing heads that flow better, but maintain the same combustion chamber size to keep the stock compression cause no more stress on the motor either.
Moroso CAI/Kooks 1 3/4 LT Headers/catted Y/!muffler/Hooker tips. 17X9.5 Chrome Z06 wheels
Exhaust clip: http://www.youtube.com/watch?v=1WArqIB6esM
Post #: 16
RE: Just got a camaro... 400hp? - 6/13/2007 8:36:59 PM
98ss4REAL
Status: offline
cop ur doing the lt4 conversion! im so fing proud of u lmao.. but anyways back to the 400hp question get sone good headers to a cat-back or true dual w/e u want, and check out a ms4 cam from texas-speed.com they are the ****, check out there heads as well like jd was saying... and get it dyno tuned u will be around 400 at the wheels with that then add a bottle with a 75 shot like nick has and u will be dam happy with wat ur car does...
98 ss 65k for sale-moded
02 z28 40k for sale-stock
(in reply to 95slvrZ28)
Post #: 17
RE: Just got a camaro... 400hp? - 6/13/2007 11:46:35 PM
nickdotcom
Status: offline
quote:
ORIGINAL: 95slvrZ28
please point out were i said oxygen isn't flamable. may be hard because i never said that...
and whether its a noticable amount or not isn't the question, whether you like it or not adding intake and exhaust is increaseing the output of the motor thus adding more wear and tear.
more free flowing heads are doing the same thing, more air + more fuel = bigger bang
Post #: 18
RE: Just got a camaro... 400hp? - 6/14/2007 6:16:53 AM
JD1969
Status: offline
quote:
ORIGINAL: 95slvrZ28
Oxygen in a pure state is flamable, but in the small percentage that is in N2O it is not. N2O is non-flamable, look at the sticker on a tank somtime.
2001 SS A4
11.500 @ 116.01
Post #: 19
RE: Just got a camaro... 400hp? - 6/14/2007 3:30:30 PM
Big_Bird_1985
Status: offline
Ok the reason the 5.0 caught on fire is because the pressure on his intake was so great that it blew off and it backfired burning up his wires near there and his filter. He is an NHRA racer so I doubt he was using it incorrectly. How my friend got killed is from what the police report said he was taking a turn and he had it hooked into his throttle body so when he floored it it would spray. During the turn he pressed the gas and it sprayed he lost control went into a ditch flipped it 3 times and hit a phone pole killing him instantly. I guess you are correct in saying he wasn't using it correctly, but it is very unfortunate that that happened to him. I do not see how you can say that Nitrous is no harder on your motor than other power adders. Think about it say a 100 shot of nitrous gives you 100 hp even with no other supporting mods. If you were to do all motor and get the same amount of hp you will have to do mods that work together to keep your motor running peachy and still provide that power over a much broader range therefore doing less wear to it. Nitrous adds that amount of power in an instant and only keeps it there while it is being added.
Analogy: Which puts more strain on a rope or chain a constant pulling of say 100 pounds, or a sudden on and off jerking of 100 pounds. Which will cause the rope or chain to break first?
Post #: 20
Login OR Register now to post a reply to this forum topic.
Camaro >> Camaro Models >> 4th Generation >> SS / Z28 Camaro
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5570
spectergt2604173
madmikez284156
95slvrz283155
02stangt2989
74454bb2749
cplthomas2546
bluovlh8er2467
blade2300
spartan662250
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
