Which power maker should I use
[Poll]
| Nitrous Oxide |
| Supercharge |
| Turbocharge |
| Naturally Aspirated |
Total Votes : 7
(last vote on : 6/28/2007 11:00:30 AM)
(Poll ended: 6/30/2007 12:00:00 AM)
Login | |
RE: Which power maker should I use - 6/25/2007 4:38:33 PM
z28 john
Yeah! The problem with supercharging a carbureted/throttle-bodied engine is that you have to get the air-charge UNDER the fuel-source, since it's nearly impossible to seal it to the top of it! Better decide what all you intend to change (like, I'd dump the 'lazy' 307- quick!) before you start trying to decide on a forced-induction method! John
_____________________________
Two '94 LT1 Z's: one convertible, one super-charged coupe
RE: Which power maker should I use - 6/27/2007 1:31:48 PM
riceeater
the lazy 307 runs low 14s, I wanna get into the 12s an I have a 350 block I am doin this on as for compression, I have not rebuilt the motor, so obviosly low compression for forced induction, around 10.5:1 otherwise. Also, my uncle has been building motors for years an has built 3 turboed carb motors, I would get his help in that situation.
