Camaro Forums   Camaro Classifieds   Photo Gallery   Members   Search   Forum FAQ   Contact CF   Sponsors
    Camaro News   Camaro Timeslips   Camaro Recalls   TSBs   Register   Login
Big Problem..or no?
  Printable Version
Camaro Forum >> Camaro Models >> 3rd Generation >> V6 Tech >> Big Problem..or no? Page: [1]
Login
Message << Older Topic   Newer Topic >>
Big Problem..or no? - 6/16/2007 9:53:13 AM
raiders21289
Score: 0
Status: offline
hii guys im new to this forum buh i have a 1986 2.8 liter fuel injected camaro...nd heres the thing...ill start the car and it wont idle...buh if i put a jumper in the box under the steering wheel the B+A one then itll idle and i loosened the distributor so i can mess with the timing because i think thats the problem buh ive had it timed and it keeps throwin it off.....and it all started wen i heard the engine backfire...now itll back fire on every rev....soo im stumped..can anybody please help me? thanx
Post #: 1
RE: Big Problem..or no? - 6/16/2007 1:47:13 PM
z28pete
Score: 0
Status: offline
z28pete's photo gallery
Is the check engine lite lit?
_____________________________
Pete
(in reply to raiders21289)
Post #: 2
RE: Big Problem..or no? - 6/17/2007 12:07:31 AM
raiders21289
Score: 0
Status: offline
yes the check engine light is on..... it turns on after like 2 mins. of running...the acceleration also bogs,it pops near mass air filter when reaching 3 rpm's.
< Message edited by raiders21289 -- 6/17/2007 12:18:46 AM >
(in reply to z28pete)
Post #: 3
RE: Big Problem..or no? - 6/17/2007 9:10:21 AM
z28pete
Score: 0
Status: offline
You have to pull or flash the trouble codes (DTC) and it will point you to the trouble that the computer sees.
Flashing codes at DLC connector:
Turn key to OFF
Connect pins A & B together
Turn key ON, do not start engine
The MIL lite will flash code 12 three times (Flash, short pause, Flash Flash, long pause, repeat)
If there are any DTCs, they will now be flashed three times each, starting with the lowest number to the highest.
When all the codes have been flashed, the MIL lite will flash code 12 again, indicating that all codes have been flashed.
Now you need a chart to tell you what each code meant.
Pete
Post #: 4
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Camaro >> Camaro Models >> 3rd Generation >> V6 Tech
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
z28pete5570
spectergt2604172
madmikez284156
95slvrz283155
02stangt2988
74454bb2749
cplthomas2546
bluovlh8er2467
blade2300
spartan662250
New Vendors
Borla Performance industries
AMSOIL - Performance Oil Technology
MagnaFlow Performance Exhaust
Camaro Forums .com is not affiliated with or endorsed by Chevrolet Motors Division or General Motors.
